Raised Hitch Cargo Carrier
Commander
I currently have a Rola hitch mounted cargo carrier and hate what it does to my departure angle. Has anyone modified a hitch carrier to make it higher? I want to cut the attach tube and re-weld it so it is raised about 18-24" higher. I have searched the web, but cannot find any examples of this.
Has anyone done this? Did it cause any problems? I would love to see pictures.
brp
You could get a high-low receiver adapter. I think they make them around 12" but you would have to check.
Mass_Mopar
Don't Litter
I did that, didn’t bother to weld it just reused the bolts the rack came with. I had to section it to fit around the spare.
Mass_Mopar
Don't Litter
Nope. That said it's a big pain so I only use it if I absolutely need to transport a Jerry can or two.
Before
wxeG2JTYotn1-qcXC32LPE8OMZ5amxQ0eRO3G00hJCbdSUWQS4vAx7GFT742gTC11-vEH5UD-fl_GPVYob1c8-PakSWppOiUtzlZWO49jcCpGW6iSDSHNckYTGMYDsyp0yA3Tuh9Sac=w848-h477-no
After
yqNot01GQPggCZQa9H7AptAosnS8s4VUS79uxAe8jVj05QXnXO9I9mOA5GLTEiTzO3Rv9N5mFy8XSsiFJ1s9ogKGxFCom6WKZ68KTGWBVwt716_pHg2UeKy9nfvhBRaOwgG9J6u8cRg=w848-h477-no
rtaylor
I’ve done it. As simple as it sounds. I raised mine 10-12” by replacing the male tube that goes into the hitch. Made a new one with two 90s in it to make it taller.
Commander
Awesome! Do you have any pictures? I would like to duplicate it. Was 10-12" enough height to avoid scraping it?
rtaylor
Pictures attached but none of the basket mounted to my LC. It’s helped a lot but I’m not getting too extreme.
bluejeep
just a guy
I purchase one that already had the 'rise' incorporated. Then I modified it so I could have the 'rise' change to a 'lowering' because I had a 2" receiver incorporated into a rollbar cross member across the top back corner of the roll cage. In the 'flipped' config it sits just above the spare tire. Nice for trail riding up there, and yet still able to get it out of the wind down low for hiway riding.Slide2.JPGSlide3.JPGSlide1.JPG
Mitch Bears
