Thanks for the reply! I have been running my tires at 25 psi which seems high for my load. I’ll dig up the charts and see if I can find the best psi for my setup. Thx!Have you tried a lower tire pressure? Normally, the advice on trailers is to run max pressure but big LT type tires need very little PSI to safely hold up something like you have. I bet 15 PSI is more than enough - that's what I ran on my last trailer with 30x9.50 mud tires even moderately loaded. It towed and handled awesome with short, stiff trailer springs and no shocks.
There are load inflation tables out there that can show you how much air is required based on actual load. My bet is that your total weight isn't even on the chart, meaning you only really need enough air to keep them on the bead.
Your trailer won't behave right no matter what until you fix this...So I ran to my local commercial scale and the trailer actually weighed in at 1000lbs. I also weighed just my truck with the trailer tongue attached and without the tongue attached. There was a 40lb difference so I’m assuming the tongue weight is roughly 40lbs?
I don't like running lower pressure in tires on a trailer with tendency to sway; it seems to amplify the sway.
Stomperxj knows his stuff. Try that to soften springs. But you still have to deal with the tongue weight.
Some guys were running Ford ranger springs with some leafs removed on light trailers. Longer springs for the same weight rating give a little better ride is my understanding.
Look through builds on similar trailers here, there's lots of them and lots of good info to learn from.
Yes you are right!for this rig he can just sit it directly on a bathroom scale since he only needs 100-150# on the tongue.
There is a lot of good advice in this thread. For sure the tongue weight needs to be right; that can be done by adding weight to the front or moving the axle rearward. I like the idea of longer tongue and cooler myself, sort of a two for one deal! Several guys are advising shocks, but dampening probably isn't going to help you in this case. I believe your suspension is too stiff for the load it's carrying. Your current springs are about 26" eye to eye with three leafs - betting that's 1500 lbs each or so rating, which is way too much. Your trailer springs aren't holding up the axle or tires which probably account for a third of your trailer weight. That means your suspension is only holding up around 700 lbs or so. After the tongue is sorted out, play with tire PSI and try removing that bottom leaf (or two). I would wager you will find that your bounciness is resolved or greatly diminished for basically zero dollars that way.
It is possible to get the suspension on a trailer to the point where it can carry your load and is soft over bumps but then rebounds terribly - that's when you need shocks. Automotive leaf conversions (Jeep, Samurai, Ranger, etc.) tend to fall in this category. It's a fine time proven design but for your little rig I would submit it's overkill and not worth the effort.
Hey guys,
Just wanted to add an update. So far I have been able to extend the the tongue 24”, added a tool box to the front of the load box on the tongue, removed the small bottom leaf and put in shock dampners(Gabriel’s).
The up and down bouncing has been reduced a good amount and the trailer pulls much better, as well backs much better. The new tonight weight is 110lbs with the box loaded. Still a bit light but still working on the loading part.
The trailer still wants to teeter or walk side to side a bit but I’m starting to think it’s the rad mounts on the leafs that are on the weak side and have more flex and movement thn they should. That along with the narrower wheels base(compared to by truck) and the weight of the side boxes.
I’ll lost some pics soon but just wanted to thank you guys for the help. The trailer is gettin there.
