Stuck rear camshaft seal.
icant4x4heretoo
1999 Montero SR
So the driver side is stuck.
it won't rotate.
I have broken off the bottom ears.
Im doing maintains so I already removed the intake.
what can I do or tricks to remove this.
I have not done the passenger side yet. in fear that i may break that one too
nwoods
it won't rotate.
Im not sure I understand your description, or perhaps my 3.5L SOHC is just different from yours, but I just did this job recently.
Passenger side is a cap plate with a cylinder shaped end plug that has a round O-ring on it. Very easy to remove. Here is a photo of the back of the passenger side. Ignore the dirt!
Here is what it looks like removed from the head:
I use a small set of picks with hooks from HarborFreight to remove these seals:
On theDrivers side is a sensor unit that has no direct seal or O-ring to it. Per the manual, you need to add a bead of RTV gasket sealer to it. This is what the back of the engine on the drivers side looks like on mine:
Here is what the manual shows for this sensor location
icant4x4heretoo
I forgot to add the year and model. Its 99 Montero SR.
Yes it similar but mines is stuck on the driver side. And it won't move. after I broke off the ear at the bottom. trying to pull it out. It won't rotate or move a bit out off the head.
nwoods
Sounds like the gasket sealant is working to hold it in place. If it’s not broke, don’t fix it
icant4x4heretoo
By using WD-40 and tapping it for about an hour. I got it off. Once you break the seal of the old crusty oil. And you get it to move/rotate. Start rotating it a couple times. Continue to rotate it but now start pulling on it. This will continue to work the WD-40 into it and help break the oil seal.20181112_135913.jpg20181112_135904.jpg
Breezy78
