Generation Zero Tundra Co-opskis T100
Co-opski
Getting the build thread going here. Not much new but getting the new engine put in this week.
OWNER: Co-opski
PURCHASED: July 2017 with 124,000 miles
YEAR: 1995, July 1995 build date
MAKE: Toyota
MODEL: T100 DX
PAINT CODE: Cardinal Red (3H7)
ENGINE: 2001 5VZ-FE 3.4L V6 DOHC producing 190hp at 4800rpm with 220 lb-ft at 3600 rpm NGK wires, NGK Laser Double Platinum plugs, Mitsuboshi timing belt, Aisin water pump, NSK bearings.
TRANSMISSION: 4-Speed automatic 4AT ECT, 4wd,
REAR DIFFERENTIAL: Toyota 8.4" 12 bolt 1.31″/30-spline
SUSPENSION:FRONT: Bilstien HD shocks and torsion bars
REAR: Bilstien HD Shocks leaf pack
GAWR: 2200lbs
GAWF: 1818lbs
GVW: 6000 lbs
TIRES: Summer Dunlop AT 265/70 R17 Winter 245/85r16 Mastercraft carbide studded load range e.
WHEELS: 17inch FJC 2014 wheels Summer 6 bolt on 5.5 lug pattern. Winter steel Toyota 6 on 5.5. stock 16 inch
BRAKES:
STEERING:
ELECTRICAL:
Scan Gauge II http://www.scangauge.com/
Ram Mount Garmin CSx60 hardwired into electrical
Hella Supertone horns
Brake controller
LED interior lights
RECOVERY:
fire extinguisher
Black Diamond Tele-bobcat snow scoop.
OTHER:
Vagabond Canopy
Yakima Rack on canopy
3 Yakima 66 inch crossbars, hull loader, wind screen, basket and gun whale brackets.
Marathon seat covers http://www.marathonseatcovers.com/ca...eat-covers.php
Small Action Packer with tool kit
Co-opski
well winter in Alaska has not been good to my truck. I've been hit and rear ended twice this winter and Allstate is wanting to total out the truck and it is just the bumper and a few hits to the body dents. We are all okay.
deadbeat son
Glad to hear you're okay, sorry to hear about the truck. It sounds like you may be able to salvage it?
vertical.dan
