fire extinguisher recommendation requested
Scoutn79
Subscribed...curious what people are going to recommend. I have a 2.5 lb powder extinguisher. but something that didn't make quite as much of a mess (halon?) might be nice.
Darrell
One shot
Some in previous threads have said not to bother. Spreads too fast, and if it’s behind the dash you won’t be able to put it out. Best to use the time getting out.
s.e.charles
interesting perspective and I do understand the philosophy behind it. I used to work with a volunteer fire-fighter. he explained how to use a small fire extinguisher this way:
1. remove fire extinguisher from bracket
2. pull pin; throw fire extinguisher into fire
3. get the hell out of the car/ building
4. call the fire department
but I still think I will get something to, if nothing else, throw at the fire.
just not sure what i'll get.
mep1811
Gentleman Adventurer
I also use the Element 50 second unit
This video shows a discussion with world-renowned comedian and car collector, Jay Leno covering some of the many advantages of Element fire extinguishers.
s.e.charles
the Element gadget looks cool*, but does anyone here have real-world experience using one? and, is my understanding the chemical reaction does not compromise surrounding materials & surfaces correct?
*fun intended
steelhd
Avoid ABC extinguishers and use BC instead. If it happens to be a small fire in the cab or under the hood and you save the vehicle the A component will get into electrical connections and completely wreck things. BC doesn't have that drawback.
NatersXJ6
I’ve gone over completely to the Element Extinguishers in my kitchen, garage, and all cars. I really believe they are disruptive technology and will take over the industrial world someday.
I have considered starting a series of demonstration fires just to try one in real life. I’ll video if I ever do.
s.e.charles
re: Elements - hoping they are able to bridge the gap between theory & practice.
I suspect fire extinguishers are like knives in the respect that the "best one" is the one you can grab in an emergency.
krick3tt
I use a Kidde extinguisher. Mounted behind driver seat. Probably not the best choice based on this thread but they are everywhere and easily replaceable.
davescott
Hose clamps to mount extinguisher on diagonal roll cage bar at rear of Jeep works best for my 5 lb extinguisher. Out of the way but easy to get to
Scoutn79
Secure but how long does it take to find a screwdriver and unscrew the clamps to get to the extinguisher?
Darrell
DanoWall
