Pinnacle Campers
Chateau spotter
Chassis now for sale, not 4x4 but could be easily,
forum.expeditionportal.com
Like many on this forum I have a thirst for adventure travel. Over the past couple years, I have built up my I'M BATVAN! for that use.
During that time, I have used the van for work duties too. As a remodeling contractor the v10 powered, 4x4, 1-ton van has been great for trailer pulling, in and out of jobsites, etc. But “work” takes its toll on things. Point being, it’s a tough balance for vehicles to wear so many hats.
So, I needed a “work truck” again.
The steel body of the van and single pane glass has compromises on the camping side of the pro/con list as well. At some point I decided a dedicated camper was in my future. In fact, I would like to do some long-term expedition/overland/global travel in my future (like 8-10 years), and my goal is for the vehicle to be designed and assembled by myself and my “team”. Those trip plans are a long way down the road. But why wait? When it can be used and tested now. At the same time maybe, this will just be a prototype or proof of concept for a future build, there are a lot of mistakes to make and things to learn I’m sure.
So I needed a “base vehicle”.
Being a carpenter by trade, and a hobbyist mechanic the only clear option is a “BMO” (Build My Own) scenario. I do have some upcoming projects that will be used as tests for my box construction methods and techniques shortly.
You could maybe think of this vehicle as a “jig” for the camper build. With the camper box potentially ending up on a different (E-series) chassis altogether. Quite frankly, with the newly built flatbed sized specifically for this vehicle the bed has little worth elsewhere.
I will elaborate more on the details of the camper box plans later as it becomes a more immediate project.
So what vehicle to chose that has familiarity, will be good for work, trailer towing, etc. in the near term and be a good base vehicle candidate to design a camper/expedition camper around?
How about a 2011 Ford E350 cutaway chassis? Haha, it looks ridiculous!
This is a retired ambulance that had its box removed (and refitted to a new chassis) just before my purchase.
I have often wondered why the E350/450 cutaway chassis aren’t used more often as an “expedition” chassis. I mean it is the best selling, longest running line of motorhome chassis in the US.
Maybe it’s the stigma it has gotten from that “stick and staple” RV industry itself? or, ?
Obviously, there are the service issues for this chassis in a RTW scenario. In my case, I think chassis familiarity and the ability to acquire parts anywhere in the world from anywhere in the world (with an internet connection) can overcome this.
Maybe it’s the fact that the chassis never came with an engageable front axle from the factory?
With 4x4 chassis converters and now even a couple options for DIY 4x4 conversions, this isn’t such a big issue. Build it from mild to wild.
Regardless, there will be many good used or refurbishable chassis available for a long time, and new until 2021 I think.
Multiple motors to choose from over the years.
This chassis is equipped with the 6.8L V10. In my current E350 daily driver I have found it to be dependable for the last 55K miles.
Its really hard to get around the poor fuel mileage in this weight category. I prefer gas (over diesel).
I don’t see it as being my best/final motor choice for the end use of this vehicle, though I think this motor will work fine for this project.
The motor is cheap to replace, or the chassis can be re-powered with something else relatively easily.
It has a between the frame rails 40 gallon tank, I think its ample. It could possibly be increased to a 55 gallon with that size available in the longer wheel base cutaways, or one could add a van style mid-ship tank of 28 gallons (after cutting it down to fit the transfer case) or an aftermarket mid ship tank of 35-46 gallons bringing total potential capacity to the 100 gal. ballpark.
This motor is equipped with dual alternators and is backed by a 5 speed auto. The same 5r110 transmission in my current e350.
I purchased the chassis from Arrow Manufacturing in Rock Rapids, Iowa. They were easy to deal with, owner of the company even picked me up from the airport 45 miles away.
They have many chassis on site and coming in regularly. They even had a 2003 e350 7.3L diesel with 34K miles. Another great option.
Part of my “testing” is to first off build a flatbed. Not because I plan to build the camper box on the flatbed but more importantly I need something to cover the frame rails for now.
Semi simultaneously I will be removing the front suspension and installing an engageable Dana 60 front axle from a F250/350 pickup, new shocks/springs, rear suspension adjusted for final ride height and to convert from the dually wheel setup to single rear wheel offset type wheel all the way around. I will install the transfer case and driveshafts at a later date.
Initially just get it looking decent, on the road, and earning its keep.
As the plans are being developed for that and parts acquired, I decided to tackle a rear bumper project.
The box tail lights were temporarily mounted to the frame (not to mention the double 2x4 mudflap hangers Arrow provided for the drive home) so I wanted something more permanent to the chassis as the possibility of a couple mounts and re-mounts of the bed/box could be in my future.
The bumper design is something I saw on expo a while back (casa azul maybe?), a 4” tube bumper with cutouts and taillights protected inside the bumper tube.
Hoping that my overall estimated future dimensions are correct I chopped about 16” off the chassis frame rails with my plasma cutter.
Cut off the lower smaller flange, I then flipped them over and attached to my frame. To be sandwiched by a brand new tow receiver.
I also cut a profile into the new bumper supports to cradle the tube bumper itself and welded everything up.
I cut some holes in the tube for a pair of tail lights with the plasma using a cardboard tube as the jig.
….and used some expanded mesh in the bumper cutouts. Here I'm using raw weld-on stake pockets to pull the mesh into the holes. Brackets are tacked inside for the LED taillights.
Installed some 4 way, LED, taillights from superbrightleds.com
For now, I just shot the bumper with rattle can satin black. I have plans to expand on the bumper later with tow/extraction points and a spare tire mount. Ahead of the bumper above the receiver is a nice open spot, rear mounted winch? Winch reminds me, I wouldn't mind taking on some sponsors with this "project vehicle". There are a lot of parts and pieces (I've started a list) that will go into this thing in order to make it "expedition worthy". For inquiries PM me.
I also shot the cab with Oxford white Raptor liner. Not really sure why its white, other than wanting to get rid of the orange stripe, I didn’t want to paint the door/hood jambs.
Here is a preview into where I’m at now. I will go into more detail in future posts regarding the F/R axle installs and the flatbed build.
2011 E350 Cutaway chassis Project truck: Almost 4x4
2011 Ford E350 cutaway chassis Project truck “almost 4x4” Located in Boise, Idaho 83712 $24,000 TLDR: This was a former ambulance with its box removed, a cab back installed and a makeshift plywood flatbed. F350 axles have been installed and it is a good running RWD truck. To make it 4x4...
