High Amp weatherproof connection for Truck bed
shade
300w is one residential panel.
I plan to have two wire runs. One for 20' and the other about 50'. Trying to minimize voltage drop. Look at a wire gauge calculator. You'll see. ;-)
Is the 20' fixed, and the 50' the cord used for dismounted positioning?
PSea
No. Both are extensions running from the anderson plug at the trailer. Then i just use the length necessary. In the worst case, I could combine tgem for 70' but would expect significant voltage drop. Panel is 40lbs. Less than a jerry can of water...
dreadlocks
House panels are higher voltage, my 325w is like 60v, with 100ft of 12awg I loose less than 10w..
I use tinned marine copper stranded with Anderson's..
shade
The panel is probably more awkward than heavy, but 40 lbs seems reasonable for 300W.
What did you decide to use for the extensions? There are 8 & 10 AWG cords available at reasonable prices, but I don't know who makes good ones. Yellow Jacket seems ok.
john61ct
volts are volts, amps are amps
degrees of temperature, distance
Understand how these interact, the underlying reasons for making your choices
and you can use whatever you like.
Obviously an extension type cable you take care of and look at and touch every time you deploy it,
does not require the same standard of something
intended to safely operate the life of the vehicle
permanently routed who knows where maybe in extreme conditions.
shade
Fwiw, there is a wire or cable optimised for just about everything.
Anyway, that wire mentioned is great for permanent installation of fixed solar array, but its seriously miserable stuff if one plans to frequently coil/uncoil and use it for anything portable.
Looks fairly stiff, like it likes to fight back.
Bayou Boy
Yes even a pretty small truck can get over a kW on the roof.
What expo-class vehicle's going to worry about a couple hundred pounds?
I'm not talking about the weight. More the PITA that is going to be storing and moving it around. I'm assuming he wants to use it like a portable panel. A 300w panel is 5.5' x3.5'. I have a fullsize with a camper top and wouldn't want to have to figure out how to store that.
john61ct
Yes I was not talking portable, but why did you assume that?
The folding type is for portable use, seen up to 180W per unit, can deploy as many as you can afford.
The so-called semi-flexible would quickly break down used that way.
DaveInDenver
Middle Income Semi-Redneck
He clarified that the panel is mounted on a trailer and the extension length needed I surmise depends on how he orients in camp.
shade
How about just get the jacketed pair boat cable and calling it good ? Perhaps one enjoys carrying considerable extra weight and bulk with their extension cord ?
If one is determined to extra bulk and side benefit of save time & money, just buy an appropriate Service Junior cable.
Jacketed pair boat cable would work fine in gauges that are available paired, which is why I asked about flexibility earlier.
I was speculating that he was considering a heavier gauge that wasn't.
flipstick
