crossed-up
With another Euro trip to the Alps planned in August and various issues needing to attention on the WK, I decided to down size to a Renegade Trailhawk a few weeks ago so I could spend more time travelling and less time working on the WK. Double the fuel economy was also attractive given that most of my planned trips involve 1000's of road miles to get to and from the trails.
The swap required the ‘quart into a pint pot’ project of transferring my drawer/kitchen system to the smaller vehicle. My brother has an almost identical Trailhawk so I was already familiar with some of the potential space limtitations, but figured I could come up with a workable solution, and in the end I pretty much managed to fit all WK kit in, even the waffle boards will go in with a bit of cutting.
Obviously the Renegade’s luggage space is smaller than the WK but its’s actually a lot deeper, albeit it has to house the spare wheel. After taking various measurements I figured my drawer and fridge slide build would actually fit with a bit of timing and fettling. In the end I opted to remove the floor board (quite thichk and surprisingly heavy.), and turn the spare upside-down to create a useful and accessible storage space below the draw, but I would need to make up some sort of mounting arrangement to support the drawer. I opted to make a perimeter frame of 10mm tube fastened to the rear cargo hook mounts to support the rear of the drawer, and pick up on the rear seat mount at the front. Following the mounting of the drawer I replaced the rear shelf (again surprisingly heavy) with a full width and deeper 9mm ply version as a further storage platform for some folding plastic crates. The dimensions also worked out to allow a plastic crate to fit below too if required.
Once this was all installed I realised there was a reasonable sized unused space above the fridge, so I decided to fit another drawer here.
Here are some pics of the build:
Checking the fit of stripped drawer from the WK. It just required the back edge trimming back to allow for the seat back angle.
Made a bracket to pickup on the seat mount.
Made up a lightweight frame to pick up on the cargo mounts
The fame on the RH side extends forward to support the fridge slide mount (salvaged from the WK)
Starting to take shape
Building the new shelf - 9mm ply with weight saving cutouts
Building up the drawer above the fridge.
More fitting and fettling.
Shelf support
I made a removable floor to provide another compartment to the side of the drawer
All re-carpeted and packed in!
Out on test.
More later...
Shelf support
Out on test.
More later...
