1993 Land Rover Defender 110 (Double Cab) RHD $34,000
robnelly
1993 Land Rover Defender 110 Truck. 160,000 miles. $34,000. 200 TDi turbo Diesel engine. Vehicle just imported from England. Titled and registered in Arizona. New Hancook Tires. These truck version 110’s are harder to come by. Vehicle runs great. I have pics of the undercarriage. It has rust in some places. Ton of work done to it in the last month. 480-518-2061 See below:
-Replaced fan clutch
-replaced starter
-replaced the timing belt and water pump
-all fluids replaced including oil filter, air filter, and fuel filter
-Replaced turbo charger
-Installed new steel brake lines throughout
-New brake system including front and rear pads, front and rear rotors, front and rear calipers
-New bearings
-New rear driveshaft
-replaced front crankshaft pulley
-Rebuilt swivel balls on front axle
-Replaced two tie rod ends
-Replaced Pinion Seals
-Replaced power steering pump
UncleFunk
That is a sexy truck. I don't love how they drive, but they sure turn heads. I live in CR and we are lucky enough to have the LH drives down here. I went with the 76 Series Land Cruiser instead, but I envy the 110 trucks for sure. GLWS
guapstyle
