2017 Mitsubishi Fuso FG6-136 (FG84) 6-ton 4x4 Overland Truck for sale in South Africa!
2017 Fuso FG84 4x4 with only 17,000km (just had its 1s dealer service at 15,000km)
* This truck is registered as a Motorhome in South Africa and is homologated to seat 7x persons (Driver + 6).
* This purchase would suit someone wishing to collect the vehicle in SA to travel the African continent and beyond.
Exterior:
* 5m x 2.1m x2.1m all aluminum body (excluding cab-over extension)
* Pneumatic cylinders to lift roof and tilt cab-over extension
* Body mounted on spring bolt system to allow for chassis flex
* Auto levelling rear Airbag Suspension + OE Leaf Springs
* Adjustable Front Air Shocks
* 6x Super Single Dual Valve Tubeless Steel Rims from Kym Bolton, Aus - fitted with Patriot M/T 37" x 12.5" R17 LT 131Q (1950Kg@160kph), ideal for vehicles up to a GVM of 7800kg.
* Front Bull-bar (winch mounting points provided), recovery points and 4x KC Spotlights
* Rear Tow bar assemble with recovery points
* Rear Rooftop winch to lift spare wheels
* Rear LED Work/Flood
* 2x 9kg Cadac Gas Bottles
* Exterior Kitchen with Gas Grill, Induction Hob, Washing Basin, Counter top & Pots/Pan & Cutlery
* 200L Diesel Tanks
* 200L Fresh Water Tanks (space to increase size of tanks)
* 90L Grey Water Tank
* Rip-stop Canvas Pop-up tent plus complete Add-A-Room Tent (4x sides)
* 3m Howling Moon Awning
* Roof Deck (manhole access from inside)
* Thule electric steps
Interior:
* 4 Berth (1x Dbl over cab, 2x Single Beds - convert into benches with tables to seat 4x people)
* Gas, Solar, 220v & 12v power.
* 6x 110mA Deep Cycle Batteries
* 2x 3000W Inverters
* Dometic 9,000 BTU Air-conditioning unit runs on both 220v or 24v
* 260L Gas/Electric Fridge Freezer
* Microwave (space to upgrade to convection grill combo)
* 18L Hansen Gas/Electric Geyser
* Full interior WC, Basin, Shower, Thetford C-250 Electric Cassette Toilet
* 220v/12V Fiamma Turbo Vent Ceiling Fan
* Dometic 2x Gas Hob Stove Top
* Dometic Hot/Cold Water Kitchen Sink
* 32" LCD TV
* Lots of packing and storage space!
* All aluminum interior. Lightweight, robust and easy to clean
* LED Lighting
* Manhole access to Roof Platform for sundowners
Additional spec include:
* 2nd Alternator (engine mounted) to charge house batteries on the go!
* Chassis mounted 24v Air Compressor & Tank (incl air hose with gauge to reach all 4x wheels)
* PTO with Fold-away hydraulic outriggers for levelling & stabilizing when camping / changing a flat tire, or releasing a bogged down wheel
Note that this is a Euro 2 spec engine truck as standard on South African models. The Euro 2 spec engine is particularly useful for travel on the African continent as it will run on both 500ppm and 50ppm diesel. Low sulpher diesel is not always readily available in Africa.
With only 17,000 kms (barely 11,000 miles) this truck is in near as new new condition.
ASKING PRICE: USD$ 69,995
Contact owner, Gustav Marais, direct on: myoverlanddream@gmail.com
dr. benny
Enjoying The Journey
Great looking rig! How would this work for a foreigner to purchase and register the vehicle in South Africa? Thanks.
Hi.
For a foreign national to purchase and register a vehicle in South Africa you will need to apply for a TRN (Traffic Registration Number) also sometimes referred to as ANR. The biggest challenge with this is having a local address, but I will be able to assist a buyer with this.
Not sure what your travel plans would be but note for the record that the South African model Euro 2 spec truck cannot be registered for example in the USA due to their emission laws. I assume you may have similar issues in the EU also?
The Euro 2 spec truck is however ideally suited for travel on the African continent as it will happily run on both 50ppm or 500ppm diesel. This is important as 50ppm diesel is not always readily available in Africa.
There is a vast number of tourists, especially Germans, that purchase trucks in either South Africa or Namibia to travel the continent during their holidays from Europe. They store the trucks in SA or Namibia in between their annual or more regular holidays.
So it is something that is commonly done.
Is there a pass thru from the cab to the living space?
Hi. No currently there is no pass-thru, there are only corresponding sliding windows fitted. We do however already have the build plans for a pass-thru as it is something we were going to do eventually. So this can be done for you locally and reasonably economically if required.
eclipse179
