? - Voltage Regulation when Charging an LFP Battery
Seems like this should've already been here:
I think Sterling might sell more products if they didn't all look like electric fence controllers from the feed store.
Something between the cells and alt output was limiting then.
With bare cells I've hit over 5C.
But even .5C is faster than you want for longevity.
And cause a stock alt setup too either burn, or its OCP will just drop voltage, rather than
the desired continuing at the V setpoint and just reducing current rate.
What voltage and what sized cells? I agree that bare cells can hit huge currents, but there needs to be at least 1-1.5V above the resting voltage (at the terminals) to do that. Just like with all battery chemistries, voltage at the terminals can effectively and repeatedly be used to limit charge currents to sane levels.
I don't disagree that LFP banks can destroy alternators and wiring, but so can large lead banks to a lesser degree. .
Yes, stepping the voltage up as SoC rises certainly can work, but requires human monitoring or a fragile Arduino-custom science project.
Lifeline AGM will pull .8+C but for a **very** short time only.
Best thing I have read and soooo true. I am normally all about function over form but for my SEMA Transit build I will admit the clean look of all Victron vs the Sterling design was an easy choice.
form > function then eh?.. all my stuff is hidden and nobody can see all the cool blue victron stuff anyhow.
besides, ugly ******** is how you know an engineer designed it :p
Yes, why would you install this stuff where anyone would look at it?
SEMA build :)
That is the simple answer, but yes for marketing, events, social media, videos and all that I will be putting the 150Ah battery and all the associated goodies behind a lexan panel where the world can enjoy the view.
The Transit has these nifty inset areas behind the driver and across from the side cargo door.
My goal is to make mounting panels to sink everything there and run the cables in the channels above/below.
besides, ugly **** is how you know an engineer designed it :p
I think the Apollo Lunar Module is one of the most beautiful machines ever made. Engineers were 100% in charge of that design, and it doesn't look like it'd be found next to a horse tank full of chicks around Easter. That's all I'm saying.
It's also worth noting that the Sterling documentation is poor. Technical writing isn't easy, but there are people available that do it well. The same goes for industrial design.
I'm not saying I won't end up with a Sterling Power Pro Batt Ultra because of its appearance. It offers a lot of functionality for the money, but that doesn't mean there isn't a little room for improvement. If Victron doesn't announce a DC-DC I want, there's a good chance one of these will be in my truck.
__________________________________________________
Pro Batt Ultra Likes & Dislikes
No product is 100% perfect and we won’t pretend the Pro Batt Ultra is, but it is quite good and certainly a “best in class” product. Here at Compass Marine Inc. we are big fans of the Pro Batt Ultra because it can do things no other charge management device can.
  • Dedicated Voltage Sensing
  • Adjustable Absorption Duration
  • Forced Float Option
  • Optional Remote Display
  • 1 mA Parasitic Draw When in Sleep Mode
  • Can Equalize
  • True Fully Independent Multi-Stage Charging Output
  • Buck or Boost
  • 12V & 24V Mixed Voltage Models
  • Compact Size for the Amperage
  • Temp Sensor Included
  • Can Withstand a Load Dump
  • Ignition Excite Option
  • Fully Custom Programmable
  • Easy to Install
  • Best in Class Product
  • Pricing is Very Competitive
  • Good for Drop-In LiFePo4 Charging
  • 2 Year Warranty (many other DC to DC chargers are 90 Days)
Dislikes:
  • Owners Manual
  • Programming is a Bit Kludgy
  • Terminal Strip Orientation for Temp/V-Sense/BMS is Awkwardly Located
  • Fan Noise (only when working hard)
  • Programming Buttons Vary in Location By Model
___________________________________________________________________________________________________
John, you've had some experience with this product, right? Do you agree with RC's review?
Yes all their chargers are great.
Some of their motherboards are also in Promariner products.
Ultra Pro is user-custom adjustable, and AC-DC not DC-DC.
Yes sorry, brain fart
ProCharge Ultra is the ACDC version, shared MB with ProMariner Pronautic P series.
The DCDC line that also has user-custom setpoints is the BB series, max 60A, as opposed to the BBWs.
Yeah, I'm not a fan of their naming conventions.
I'm interested in the BB1260, specifically. You know, the Power Pro Batt Ultra - Green Stripe. :)
ondmtn
