monkeyodeath
I have posted this in the past, but a 20 AH LiFeP04 plus a 100 watt panel has kept my sons CF-35 at 39 degrees 24/7 over the past month or so in Southern CA heat. If you already have the panel, a 20 ah LFP battery is a not much more...flat roof mount panel, cheap Renogy PWM 10 amp controller and the fridge.
Mind if I ask what battery or where you got it?
I think that one of the reasons I was scared off lithium was seeing $950, 100ah batteries for sale and assuming that's what I needed.
But if it's possible to use a smaller and cheaper one with good results, that's great and I could be willing to spend more for a longer-lived battery that takes up less space and weighs less. Not that it's necessarily my top concern, but weight does matter, and 140# of golf cart battery is a lot for a little truck. Especially as I do a fair amount of wheeling in mine and would like to keep as much ground clearance as possible.
