Long flatbed on a short bed truck? Head of it?
Luckychase5
So ya, that the gist of it. I’m going to look at a really nice truck, AEV bender, lift, UTE flatbed, deaver leaf springs, 2016 Ram CTD, Aisin trans. I’ve just never heard of a 8.5 flatbed on a short bed frame. Any input?
Darwin
Careful of how much weight you put behind the rear axle. Being a short bed that will be easy to do.
Personally I would just go with a regular cab long bed and add the AEV stuff if that's your thing. I think the Ute flatbeds are overpriced anyways
Luckychase5
This is an already built truck, for a great price. I’ll be looking at it soon, hopefully...
IdaSHO
IDACAMPER
When I built our truck, I did essentially the same thing.... add a longer bed than the truck was built for...
Its a 10' bed on a long bed (8') Superduty.
I added 24" of to the rear of our super-duty to make room for the cross-body box, while retaining a full 96" bed.
The camper COG as built is very far forward keeping the overall truck + camper COG well within check.
Just watch your weight behind that axle, and be prepared to address the rear suspension, as it adds leverage to the rear.
Renntag
Departure angles will be compromised. Consider the leveraging of weight behind the axle centerline.
On another note:
That F series camper looks awesome!
Simons
Popular down under behind crew cab mini trucks. Problem only arises when you overload. You end up stressing the frame and possibly bending it. Keep your payload #’s and positioning in check and you’ll be fine.
Luckychase5
Ya, here is a picture of the truck. I might contact the manufacturer to see if it could also work for long bed trucks, and sell it. I’ll only be putting a small camper on the back. Something around 1500lbs. And I will put it as far foreword as possible. I’m into the truck as a whole. Lots of quality parts, recipes, service records, 15000 more miles if warranty...
Buliwyf
Viking with a Hammer
Most of these look like a really bad idea. Every pound behind the rear axle, removes weight from the front axle. Like a teeter totter. Keep as much weight as possible inside the wheelbase, never outside.
End result: No front brakes, piss poor towing stability, sensitivity to cross winds. Been there, done that.
RAM5500 CAMPERTHING
OG Portal Member #183
Exactly
IdaSHO
IDACAMPER
I wouldn't worry about that setup at all, provided the bed is securely mounted. Ideally, you want a frame extension to do it correctly.
For the ones that shun such an idea, you might want to look at how many RV and Toter builds are done.
There are some LONG frame extensions used, and frame failures are non-existent.
There are also hitch extensions that are used all the time,
that will put just as much or more leverage on the rear as a properly done extension.
Again, no frame failures to speak of.
At least with good C-channel frames on domestics.
There is good reason why EVERY photo posted in this thread showing a taco'd truck frame is an import.
Frame failure on domestic trucks is not a thing. Never has been.
Beat on anything enough, hard enough, and it will fail, but it is far from common.
Lots of benefits to simply extend the rear as well.
No frame splice needed, no custom driveshaft needed, extended fuel lines, brake lines, etc, not needed.
You also dont kill your turning radius, or your break-over angles.
Alloy
IdaSHO
IDACAMPER
Perhaps you should provide the back story to that one, instead of assuming it applies.
Just sayin ;)
guapstyle
