2016 Chevy Silverado LTZ Z71
SoTxAg06
Krytonite stuff also looks solid
Greaseable fittings all over
I would 100% recommend kryptonite. They make a quality product. If memory serves me correctly, I had over 20K on their control arms when I sold the truck.
Edit: These are the arms off of my 2010 2500. They were beefy for sure. The only weird thing is that they didn’t have a attachment point for the ABS wire. I zip tied it to the control arm which never was a issue.
  • Like
Reactions: D45
D45
Ok, well my entire plan of buying the UCAs and then the 2.5" front kit and the 2.5" rear block just went out the window
I helped to install a Superlift 3.5" kit on a friends 2015 Silverado High Country today...….impressed with the ease of install and the ride quality, even with his 20" setup
I was going to go with the 2.5" kit and then the 1.5" body lift later in the year. Why do two things twice and have both installs take 10 hours?
SO.........I just ordered the Superlift 3.5" kit, that comes with diff drop spacers and new UCAs
I just will buy the 2.5" tall rear blocks and use the rear shock extension brackets that I have
One kit and done...….plus it will save be money by not having to buy $500 UCAs
D45
2014-2018 Chevrolet Silverado & GMC Sierra 1500 - 2wd & 4wd
Factory 17x8.0 Wheel Offset = +24 mm - Back Space = 5.44" Inches
Factory 18x8.5 Wheel Offset = +24 mm - Back Space = 5.70" Inches
Factory 20x9.0 Wheel Offset = +27 mm - Back Space = 6.06" Inches
Factory 22x9.0 Wheel Offset = +24 mm - Back Space = 5.94" Inches
Lug Pattern = 6 x 139.7
So now that the lift kit purchase is done, I need to figure out a tire size to run
My current size: 265/65R18; 31.6" x 10.40"
Superlift says with their 3.5" lift, the following tires / wheels will fit:
285/65R18; 32.60" X 11.20"
285/55R18; 30.30" X 11.20"...…......not tall enough
305/65R18; 33.60" X 12.00"
305/55R18; 31.20" X 12.00"..........not tall enough
Others say these sizes will fit:
295/70R18; 34.3 " x 11.60"
285/65R18; 32.6" X 11.20"
275/70R18 seem way too small: 33.20" x 10.80"
285/75/18 seems like a tall tire that might rub: 34.8" x 11.2"
285/70R18 seems like a nice size: 33.70" x 11.20"...…….not at tall as the 285.75 and a tad taller than that 285/65
D45
I'm also looking for some clamp mounts for a shovel and axe in the bed...…...any ideas?
I like Quick Firsts because they are rubber and wont rattle
D45
I need to add one or two smaller LED light bars to the inside of the cap
Any mounting ideas or where to put them?
Grassland
How is a 285/65R18 considered possible at 32.6 tall, but a 275/70R18 considered way too small at 33.2, which is a half inch taller???
D45
You're right...….I would like to try for something atleast 33" tall and atleast 11" wide but I don't think anything over 11.50" will clear?
I need to measure clearance today
Both are out!
285/65R18; 32.60" x 11.20"
275/70R18; 33.20" x 10.80"
D45
Updated list:
285/75R18; 34.8" x 11.2"
285/70R18; 33.70" x 11.20"...…….not at tall as the 285/75 and a tad taller than that 285/65
D45
Found lighting for inside the bed cap.....
I ended up buying small mini LED light pods for a motorcycle
Small and lightweight yet powerful.......self tapping screw in the mounting bracket to the aluminum window channel
They will be here next week
D45
I ended up buying two sets of LED lights for inside the cap...……..since I wasn't sure which will be better
#1
6" long x 1.70" wide rectangular LED
9W each
Super White 6500K
Epistar LED
1800 lumen
6 LEDs
30 degree flood beam
#2
3" x 2-5/8" oval LED
10W each
6000K
1000 lumen
9 LEDs
Spot Fog beam
I will hopefully decide which works best for inside the cap and get them wired up and mounted this weekend
D45
Reading through the Superlift 3.5" lift kit install instructions...……...
The kit comes with 2" tall rear blocks, that they want stacked and placed ontop of the stock factory 1-1/4" tall block.
I have always always always heard this is a BAD idea and the blocks may shift
Well I am not crunching numbers to see what size rear blocks to buy, so I don't have to stack blocks
D45
Rear with 2.0” Blocks (Stacked on Stock Blocks):
Driver Rear: 39.875”…………………..1/8” taller than front
Passenger Rear: 39.125”……………..1/4” lower than front
Rear with 3.5” Blocks (Not Stacked – 2.25” rear lift):
Driver Rear: 40.125”…………………….3/8” taller than front
Passenger Rear: 40.375”………………..1” taller than front
Rear with 4” Block (Not Stack – 2-3/4” rear lift):
Driver Rear: 40.625”…………………….7/8” taller than front
Passenger Rear: 40.875”………………..1.5” taller than front
I am going to shop for some 3.5" tall blocks so I don't have to stack anything
Grassland
That's some pretty tall blocks. Stacked blocks is the worst, so I'd take a 3.5" block all day long before I stacked.
3.5" will be ok for DD it you will likely see some axle wrap in deep snow or off road.
Psyph
