moose545
Dual battery Plans in the works, few questions and sorry for the long-winded post.
I plan to build a battery box enclosure that will rest behind the future Goose Gear drawers. I've still got a few questions prior to attacking the building part, such as:
2-AWG or 4-AWG run from primary battery to the AUX battery? I think 4-AWG is sufficient and a 15' kit will work
(- will run through a 40A breaker, + through a 40A to a RedArc 1225BCDC) Not sure the Redarc will take a 4AWG wire though?
3/8" or 1/2" plywood to build the box? I ended up going 3/4" for extra area to screw things together
The enclosure will house a few gauges in the upper part such as voltmeter, USBs, etc, along with the battery secured internally. Externally the entire box will be screwed to the GG base plate.
Initial plan is to run another X2Power 27F, which is roughly 100 Ah, but should you run more to run a fridge, lights, and room to grow in the future such as a water tank/pump and whatever else I haven't thought of yet that will pop up? Battery options are here, and while the monster one has less of a warranty than the 27F, it's still much cheaper than a lithium option from Victron. I think the 27F is fully sealed and ok for use in the cabin, but not 100%, of course the more expensive one states that clearly on the website linked.
Examples:
https://www.batteriesplus.com/productdetails/sli27fagmdp
https://www.batteriesplus.com/productdetails/sli8dagmdp
I plan to run 100-200W folding portable panels but haven't decided on which ones, they will go to the RedArc, and monitored with a Victron unit. Seeing how the battery isn't forever, the box design needs to be serviceable. Should/can I hook up say a 50/100A Anderson plug to the battery, through a grommet in the enclosure, and have an easy plug in/swap option there, or hardwired only? Still drawing up the diagram, neatly
I found a cool program called SmartDraw that's free for 7 days and gives you CAD-like abilities with preloaded symbols for components and circuitry that is pretty slick, posted what I've got so far below, still a few questions:
Here is what I’ve got so far, where would a switch panel go? Also keep in mind all “G” gauges will be powered to the Safety Hub. I haven’t decided on what solar panel yet. Also want to use the second battery as a starter for backup if I can, so I’m not sure how to run 4AWG into the Redarc, or if it’ll accept that gauge wire? I was trying to use a 50A Anderson plug to the rear battery but it’s not a direct run, so that’s out for now. Thoughts?
Examples:
