Dual battery in-cabin and Solar setup
rayra
Looking at the safety hub again, I think that's way overkill, and a simpler 6 circuit fuse block would be just fine don't you?
eh that's basically the product line I have in my rear cargo power box. But that's mostly out of concern for exposed terminals and possible water sloshing around back there.
I'm not really a Blue Sea promoter, although I do use a couple of their products.
I've got about 9 things going on in that back box, and maybe more to come. Might be stuffing (4) 10Ah wheelchair batts in there, wired so they get charged by vehicle and solar, but diode-isolated and wired such that they only feed the various power ports in the box. If I push forward with my camper-trailer plans late this summer / early Fall, I'll forego those and put the time and money into a ~200W standalone solar setup in the trailer, which can still be coupled to the vehicle.
john61ct
So if the batteries I listed, if you were to choose one, which would it be and why? I don't plan or want to use lead-acid, so AGM or the Renogy gel which I know is fully sealed.
I would not use any I think.
Deka makes fantastic FLA but their AGM are meh, same as Trojan maybe even Rolls.
Not Renogy afaic, they manufacture nothing afaik like Interstate
unless you learn their GEL is made by Deka, those are good, but GEL is very fussy, only lasts (very) long if precisely coddled.
I won't reco X2 beyond as I said talk to Northstar tech support, all three makers I reco'd have great support, easily available.
67cj5
Man On a Mission
If a person uses Sealed FLA's then I can't see any problems coming up, Batteries with screw top caps might be a problem for interior use when Charged at a high rate, But I would be going with FLA's.
john61ct
Sealed FLA is an oxymoron, for me it means you have access to the electrolyte, use a hydrometer etc.
In deep cycling, there are only AGM or GEL if you (really) need sealed.
FLA gassing is really no problem, if the smell bothers you vent to outside.
67cj5
Man On a Mission
Why is it an Oxymoron, Most Deep cycle batteries are made that way,
My Deep Cycle Batteries are Lead Acid Batteries and are Sealed and have a small vent valve on the end, and the can be discharged right down to 30% SoC @ 600 times and have a 5 year Guarantee,
Mine are the 115Ah version of these.
john61ct
All lead batteries are lead acid batteries.
The three categories of deep cycling units are either
flooded (caps, not sealed)
or sealed.
AGM and GEL are the two sealed chemistries.
Any battery **can** be discharged below 50%.
None of them **should** be. Firefly Oasis uniquely withstand such abuse if it truly is unavoidable, like maybe living off grid on a sailboat.
Mfg lab tests do not reflect real world usage.
Forget guarantees, not a useful indicator.
john61ct
I doubt a proper battery for true deep cycling usage.
But your choices are greatly limited outside north america, the reco's made above are often unaffordable there.
67cj5
Man On a Mission
I can buy all the top of the line batteries like Rolls etc but the cost kills ya,
Over here for the cost of a 100Ah Lithium battery I can buy 11 of those batteries in that link I posted,
I just bought a new 35/400 Ah linier Lead Acid Charger, because my other one is too big to drag around and my Smart Chargers are too slow at charging lead acid batteries,
john61ct
Yes since excellent Deka FLA are only $1 per Ah @12V here
as cheap as consumer / automotive crap Starter motors
and can easily last 8+ years before hitting say 70% SoH as EoL
you need to really have strong motivations to spend more than that.
But I've seen many Rolls banks go for over 15 years, and many owners have the money so why not?
67cj5
Man On a Mission
I did think of going and getting some of these kits, they make em up to 14.88Kw but my last ordinary deep cycle batteries lasted over 9/10 years so I don't see the point in buying these monsters,
moose545
I ended up going with a Duracell AGM, for the price I couldn't resist. Just had to redo the box I made as the first one was too big for the space, so I'll be drilling and mounting things this weekend and then getting it all hooked up finally. I thought about holding off and checking with a local RV shop I had things sound, and what/where I insert an isolator to switch to one battery or the other like the Blue Sea switch, but I'm just so damn eager to get it rolling now. Just want to make sure it's electrically correct
dhuss
