Modifying the external dimensions of an ISO shipping container...
MTVR
We may end up being a couple of inches too tall, so I'm wondering how much could be trimmed off the bottom "skirt" of a standard 20-foot ISO container- the hollow area underneath the floor that leaves room for a forklift to get under it.
You can't use a high cube?
Sent from my SM-T860 using Tapatalk
LOL I thought "we" in we might be too tall was referring to the occupants needing more head room.
MTVR
Lol, no. That would be going the wrong direction. The bed of our truck is 5'6" high, so a standard 8'6" container would make us 14 feet tall. A high-cube container would be even taller.
MTVR
As long as you are not relying on the structural integrity that hollow, double floor provides.
We would not be relying on the structural integrity of the floor- we could simply weld the container directly to the bed of our truck, which would serve as the new floor...
1000arms
Just let a lot of air out of your tires and drive slowly! :cool:
1000arms
How much effort to remove the current bed with something lower? Would it be enough?
Do some of the MTVRs come with a box on the back? Can you (reasonably) get a box if they do?
Most rigs don't like 4x4 wood frame construction, insulated, and skinned inside and out with 3/4" plywood, but I don't think that would be an issue for your rig. :) Fiberglass, or poor person's fiberglass, on the outside ...
MTVR
The bed needs to be that high, to clear the 53" tall tires when the suspension compresses.
billiebob
so why the question ? heck as suggested cut all you want slice the wall. 13'6" is the legal limit, if you are 14' tall.......
billiebob
there is not 6" in the floor, cut the wall, drop the roof 6" or more, legal is 13'6". Not 13'7".
For all that work it might be cheaper and much lighter using composite panels cut to the right size. Unless a shipping container is somehow core to the design?
Sent from my SM-N975F using Tapatalk
NDC
