Bugeye's GX460 Build
bugeye1257
RSG Sliders:
Got the RSG sliders painted and mounted this week. Sprayed them with Duplicolor hammered gray with a top coat of clear to help with the UV not fading them. Also added some grip tape to the front and rear to help with traction when wet, not the best job but I'll redo it once they need to be replaced.
moose545
How do the EBCs wear and feel, good pedal and quick stops and holds off road? What about your bump stops, was that a need or just an upgrade?
bugeye1257
I like the EBC pads a lot but I would choose the yellows instead of the greens that I have on now. The yellows are more aggressive and better suited for a heavier rig with bigger tires ect. For the bump stops, it can be a need depending on what size tire/lift you are running, long travel, bigger tires ect. Also helps if the the tire is rubbing and so you dont bottom out your shocks.
moose545
Awesome, been running Hawk greens and reds are too expensive. I'm on 35s w/KDSS, 3" IMS.
moose545
RSG Sliders:
I really need some JDM rocker panels, mud gets up into the door jam and it’s annoying and a pain to clean. Are they eBay only?
bradbarbz
