2016 Chevy Silverado LTZ Z71
30" curved LED light bar installed quick a d easy
Removing the radiator cover and the grill was quick and easy.
I just had to wire in a 8" ground wire
extensionSnapchat-490714779.jpgSnapchat-1124788527.jpgSnapchat-2128606012.jpgSnapchat-1682628251.jpgSnapchat-784941687.jpg
Rear with 4” Block (Not Stack – 2-3/4” rear lift):
Driver Rear: 40.625”…………………….7/8” taller than front
Passenger Rear: 40.875”………………..1.5” taller than front
I made the decision to go with a single 4" tall tapered block...…….yes its tall, but I will make it work
Stacking the factory 1-1/4" and the Superlift tapered 2" block would net a 3-1/4" rear lift anyways
The rear end should sit around 3/4" to 1" taller
The Ready Lift #26-3104 blocks and u-bolts are very nice
The blocks are cast iron and are coated in a nice thick corrosion resistant paint
The u-bolts are also coated in a corrosion resistance paint
Tapered, so they measure 4-1/8" x 3-7/8"
I replaced the trucks cabin filter today
Took under 5 min
It was dirty but wasn't too too bad
Creeping up on 60,000 miles so I assume the dealer changed it before I bought it
Need to do an oil change soon also
Next Sunday I plan to install the lift on the rear end, which basically will include the rear shock extensions, rear lift blocks, and rear brake line relocation
Sunday I will also start removing the front end components and install the front end lift Monday
Trying to tackle the entire lift in one day was manageable, but I feel we rushed through some things and I want to take more time on my truck
This week I will shop for tires, either 295/70R18 (34.30 x 11.60) or 285/75R18 (34.80 x 11.20)
I am leaning towards the 295/70s
Nice. I had 295/70R18 on my last Ram. What brand/type of tire are you looking at?
Honestly not sure...….not a mud terrain for sure.
Something like an aggressive AT tire, but it will boil down to price and availability
I had the nitto ridge grapler in that size. Kind of middle ground between the mt and at. Up until those I had run BFG ATs with success. Had duratracs once, but I didn’t care for them.
Ready Lift 4" tapered lift blocks compared the Superlift 2" tapered lift blocks
Ready Lifts are far superior in my opinion, due to the front and rear tabs that help to LOCK the block onto the pad
Ready Lift 5/8" thick u-bolts compared to Superlift 9/16" thick u-bolts
5/8" u-bolts are GRADE 8 and 9/16" u-bolts are GRADE 5
3.5" Superlift installed today a long with the 4" rear block
Long day wrenching!!!
Alignment is Thursday morning
I'll get pics up soon
HButton
