A Truck Camper like no other
Avi Meyers
2019 Ram 5500 Limited 4X4 crew-cab, 84” cab to axle wheel base, 6.7L Cummins, 19,500 lbs
Wheels/tires – Hutchinson military 20” split rim aluminum bead lock, Fury 37” tires (4,200 lb load rating), Centramatic wheel balancers
Suspension – Kelderman front single bags and double bags at each rear wheel.
Fuel – 22 and 52 gal factory twin tanks
AFE Cold Air Intake kit (still to be installed)
Transmission oil cooler kit (still to be installed)
Water separator and fuel pre-filter kit
Air compressor – Oasis XD4000 with air distribution and rig for inflating all tires at once
Dual alternators (440 amps) charging camper batteries at 68 amps
AEV front bumper with Warn 16.5 winch
Camper specs:
Truck bed by Highway Products
Fresh water tank – 38 gal
Gray tank – 50 gal (converted black water tank to gray)
Fridge – 5 cu ft, 3-way, freezer
Lagun table
Queen bed w/Froli sleep system
2 burner cooktop
Microwave oven
Toaster/convection/air fryer
Propane – 2 X 20 lbs tanks
Energy – Solara Power M semi-flexible (1,150 watts) solar panels, Victron integrated system, Relion batteries (1200ah)
A/C – Cruise N Comfort marine 12v split system
Heating – Alde water and radiant space heating
Air Head composting toilet
Seagull V water filtration system
360 remote surveillance system
Cell booster
Spare pull-out 45 qt Engel freezer
Pull-out propane grill
Awning
Dyson vacuum
Outdoor shower
Watergen water maker (8 gals per day from humidity) – to be installed
motorman
WOW pure WOW
but all that technical 'detail' and product with only 2 pictures . . . ?
need more
utilities (water & electrical)
interior
storage
kitchen
cruise n comfort install
and and and
waiting patiently
thanks
m
Brewdiak
kodiak conversionator
(If SN is the real Avi Meyers)
that unicat is a real beast
Quote:“ Now, with the bruisingly solid Unicats; their smaller cousins, EarthRoamers”
funny seeing an ER referred to as a smaller cousin
cjken
19500 GVW on the 5500 but only 4200 pound rated tires? might be close on the rears.
I’m interested in this too!
The rear of my truck weighs 8000 lbs
Would tires with 4200 rating be ok if it was never loaded above that amount.
Why don’t they make higher load ratings in the 35-37” sizes.
Looks like you have to go all the way up to 41” to get higher load ratings
Fatboyz
You have to go to an MPT81 in a 41" to get the proper load rating to handle the weight of a 550 or 5500. I wish I could get a 6000 pound rated 37" in a single to replace my duals!
Darwin
Most 2000 and newer trucks probably won't even fit a 16" wheel, they would be rubbing brake calipers
Supposably those E rated 37" hummer tires are rated at 4,500 lbs. but again, it's a 16.5 inch wheel.
Closest you can get without going MPT is the 37x13.5x17 Toyo MT at 4,300 lbs.
