2016 Chevy Silverado LTZ Z71
D45
I am going to start looking into a custom tune...…….needs more power
Blackbear, Diablo Tune...……...who else is good at these 5.3Ls?
D45
Some measurements to see how the list actually turned out:
Stock with Cap:
Driver Front: 36.250”
Passenger Front: 35.875”
Driver Rear: 37.875”
Passenger Rear: 38.125”
With 3.5" Superlift kit:
Driver Front: 39.750" (+ 3.50")
Passenger Front: 39.875" (+ 4.00")
Driver Rear: 40.250" (+ 2.375")
Passenger Rear: 41.375" (+ 3.25")
The passenger side of the truck really sits alot taller................gas tank cannot be the sole reason
Rake (front to back measurement)
Driver Side: 0.50" (rear taller than front)
Passenger Side: 1.50" (rear taller than front)
Regcabguy
Oil eater.
The new Ford's air dams are ridiculous. Not only do they hang way down but the square corners are begging to hang up on something.
That's the first thing my neighbor removed on his 2018 6.7.
CountryboyNC
Stock with Cap:
My 04 z71 was the same way, driver side say .75-1 inch lower. You could really tell when measuring the distance between the springs and the overloads that they were weak on the drivers side, guess from me being in it all the time, at the time I was only about 185lbs though.
D45
Even though this motor takes 8 quarts of oil......I will never complain
The oil change was so easy and clean!!!
Kudos to GM for making the oil filter and Oil drain plug easily accessible!!!
100 times better than the PITA oil change in my old Eco F150!!!
SoTxAg06
No doubt. I can do it in 10 mins or so. It takes 30-45 to do my wife’s 4 Runner.
  • Like
Reactions: D45
D45
Trying to decide what exhaust system I want to get...……...I want a single rear pipe (rear tire, pass side exit), not a fan of the dual split pipe look
Gibson #5656 (Dual sport).....aluminized (3" pipe / 2.25" pipe)
Gibson #65663 (Dual sport)…...stainless (3" pipe / 2.25" pipe)
Gibson #315629......aluminized (3.50" pipe)
Gibson# 615629....stainless (3.50" pipe)
Flowmaster #717857 FX Series...…….stainless (3" pipe)
I am concerned about going with something such as large as a 3.50" piped system, with backpressure
I DO NOT want to spend $1k on an exhaust...……...more near $500
I am still wondering about stainless vs aluminized...….....costs and durability
buellconvert
Aluminized is just basically a coating used for rust prevention and will scrap off if damaged and it will rust there as well as at the welded areas, so if you're in an area that sees a lot of road salt, it will eventually begin to rust, but that's going to still take years. Stainless definitely looks better and won't rust, but you're paying for that over aluminized. With the quality of Gibson exhaust, I don't think you'd go won't either way.
Sent from my moto e6 using Tapatalk
buellconvert
For that price difference I'd definitely swing the extra C-note for the added looks and longevity of stainless
Timboruski
