2016 Chevy Silverado LTZ Z71
D45
2018 trucks must have diff programming and or sensors
I just installed a ported throttle body, ported intake manifold and a cold air intake on my friends 2018 5.3L Denali
The check engine light keeps popping on and it's throwing codes
Runs great with more power, just trying to figure it out
I didn't have, and don't have, any issues with my trucks mods
buellconvert
Have you checked your transmission fluid, how is the level and condition? From my experience these transmissions are very particular with the fluid level especially, it needs to be just right.
Sent from my moto e6 using Tapatalk
buellconvert
I've had a Range AFM device on my 2016 for just shy of a year and haven't had any issues with it, but I did have some shifting issues that I found was from the trans fluid being just a slight bit low, did a fluid and filter swap and it's been great since, but it never popped a code though. Have you felt any shifting issues before or during the code?
D45
What fluid type does the trans take?
I think it shifts funky......but I'm still used to my fully built billet 48RE
D45
I was checking some things under the hood this morning
A quick disconnect line (vacuum or breather?) going to the intake manifold, on the driver side of the motor wasn't fully seated and wasnt snapped into place over a fitting
Likely my error when I swapped intake manifolds.......I'll see how things are over the next week or two
D45
Good info on the 8 speed:
MAX HP: 650
MAX TQ: 635
Fluid: Dexron High Performance
Looking at the TSB for harsh and odd shifting, I called my dealership. Its not a recall so I would have to pay GM for the service? Nah, not going to happen
The issue seems to stem from “moisture content in the transmission fluid.” As such, the old GM transmission liquid is swapped for new Mobil 1 Synthetic LV ATF HP fluid. I am going to call around and get a price for a flush and fill
Dexron HP LV fluid is also accepted
D45
I am also going to start looking at a new battery for the truck........doesnt seem weak, but most are saying 4-5 year life
Rather be safe, than sorry
buellconvert
Good catch and info on the transmission TSB and fluid, I don't have the 8 speed myself, I've got the 6 speed
SoTxAg06
My 19 has the 8 speed. Zero issues in 16K miles. It did randomly throw a code, but it had something to do with me rocking the truck hard when loading a 4 wheeler without the parking break set.
D45
Anyone know what the factory battery size or any specs on it?
Advanced Auto says that either the H6 r H7 is an exact fit
Both are the same price and I have a $50 off battery coupon
DieHard Platinum AGM:
The H6 is rated for:
950 CA
760 CCA
70 AH
45.6 pounds
AGM
H7 is rated for:
1000CA
850CCA
80 AH
51.8 pounds
AGM
D45
I realized I never took off the negative cable on the battery when I previously installed the ported intake manifold
I have been debating taking it off and installing the stock part
After talking with the porting owner......i took the negative cable off and let it sit for 30 min
Truck drives alot better and has more low end ! Duh
Timboruski
