2016 Chevy Silverado LTZ Z71
D45
Well stay tuned! I ordered a diablew tuner the other day. Pretty excited.
And I agree, Definitely seems to be setup for fuel economy ONLY.
Lew does a good job at customer service.............answers questions very good
My concern with tunes are still being able to run 87/89
I do not want to rely on 91+ for performance
What octane tunes are you getting? What programmer did you choose?
Cherokee_fade
You can pick which type of tune you want in the unit. I have no plans on running 91. I bought the smaller unit.
I never understood offroad tires on 20" wheels, lol. Unless you're running 40" tires I guess
Grassland
I wonder what fuel economy will be once 34s are on the Chevy. 2 extra OD gears and different ratios might help some.
Sometimes I think about going back to stock size for the fuel economy.
SoTxAg06
I’m kind of curious as well. My 2019 has a 275/60R20 stock, which is around a 33x10.8. With the newer body style you can fit a narrow 34” tire with a leveling kit. I have the 5.3 and 8spd also.
  • Like
Reactions: D45
Cherokee_fade
Got the Diablo in the mail. I love it. I can't believe GM sold a trans the way they did, if it can work like this. I'm not convinced the tune actually makes more power, it just feels that way because it's now shifting the way it should. Should be interesting to see what a custom tune can do...
D45
My truck came with, and am still running the 265/65/18s........which is roughly 31.6 x 10.40
With the 3.5" lift, I do need to upgrade a size or two
I am hoping to find some 285/65/18, 285/70/18...........or even a 295/70/18
I would rather runs a 285/65 or 285/70.........so I do not have to worry about rubbing anywhere and I also wont lose a ton of MPG
This small 26 gallon tank is hard to get used to, compared to my old F150 with a much nicer 36 gallon tank
SoTxAg06
On the 2019+ the issue is space between the rims and the upper ball joint. Seems like if you want to run a 12.5” wide tire, you need to change rims with a different offset, or run wheel spacers.
I hear you on the gas tank. My truck has a 24 gal.
Cherokee_fade
Intake tube, Cat back.
Running 87.
It feels quicker, But it could honestly have been the torque management and shift points.
  • Like
Reactions: D45
D45
I know Lew does a good job with custom Diablew tunes........but its also $515
A used Hypertech max energy is $200-$250
I liked the Pedal Commander on my old F150........being able to adjust on the fly was a great feature
The AFM is also very annoying to me.........and I am not 100% pleased with the Range device
Cherokee_fade
I have the smaller of the two. AFM, yes. Not sure about the throttle. Although it does seem more touchy now. Like the V8s of old.
D45
I just bought a Diablo #8245 inTune programmer
Just the canned tuned for now......I'll see how it does and determined if I need or want custom tunes from Lew
Timboruski
