Victorian
Slide in Camper survey
TotalComposites is looking for your input! We love to engage with our customers and always appreciate feedback. No better place to ask a couple of questions than here on Expedition Portal
We are getting increased requests for slide in campers for all size pick up trucks. Our current panels system was not designed to serve that market. Therefore we have developed a brand new system that will hopefully solve the shortcomings of other brands. Like our bigger camper bodies, the new design will be sold as a kit without interior. This will allow you to outfit as you like! Warehoused and shipped from our HQ on Vancouver Island Canada. Turn around time should be less than 2 weeks.
We will only be offering fixed side walls. NO pop up. We truly believe that fabric/ plastic walls have just too many short comings (condensation, low insulation value, very poor sound proofing and possible weak point when it comes to wear and tear) . We can’t imagine it being fun having the bedding touch a wet fabric at night…
How will it be delivered:
Flat packed as freight FOB Victoria BC
In person pick up in Victoria BC is of course also an option!
How long to assemble the camper:
We will supply you with the adhesive, pre cut panels and extrusions. Everything is clearly labeled. We recommend two people for handling the components. Based on previous builds we are confident that you can successfully do this in a weekend.
Key Features:
True 4 season capabilities with 2” foam core panels all around
Now that we have the laid out the important technical details, we need your input:
Pricing:
A very sensitive topic…
We understand the need for fairly priced quality products. Our campers will never be sold to dumping prices as the material choices do not allow for that… But we like to ask what you think a flat packed camper should cost.
Timeline:
First units should be in stock by end of September.
Thank you in advance for your highly valued feedback!
Drawings are NOT to scale!
Key Features:
- Zero thermal transfer with our brand new super tough FRP extrusions
- Real glass awning style insulated windows (aluminum frame with thermal break)
- Panorama hatch (big opening in sidewall that is of course insulated and thermal transfer free)
- Zero wood inside the panels = No decay-ever!
- All outside corners/ jack mounts are stainless steel = No rust-ever!
- Also available with a full size bottom for flatbeds.
- Size: For added security we like to keep the main body within the truck bed so you can close and lock the tailgate. At the same time you can use the gate as a “porch”. The downside is the reduced interior space. What is your thought?
- Cab over bed: Our current layout allows for a ~48” deep alcove . This means part of the bed will be a pull out design. Thoughts?
- Width: We truly believe that the width should be kept as narrow as possible, following the vehicle outlines. This will allow you to go down narrow trails and also make it easier finding parking in confined spaces. This in return will compromise the interior space… Thoughts?
- Interior height: We need a happy medium. 78” is the current measurement. Thoughts?
- Although we think we will hit the mark with smaller trucks like the Tacoma, Ranger, Colorado… We think the more sensible way would be a Gladiator, F150 or bigger to avoid being overloaded… Thoughts?
Pricing:
Timeline:
