sideburns
Idaho 2019 Nissan Frontier CC LWB
Just picked up a 2019 Frontier 4x4 Crew Cab Long Wheel Base SV with Value Truck package in Arctic Blue last weekend to replace my 2001 Dodge 2500 Diesel. Replacing my daily driver car and the Dodge with a single vehicle, so I don't have to swap stuff between vehicles or buy two of everything.
3500 miles on it. Like new except for smoker smell and a single hole in the drivers seat cover. Was looking for a 30k-50k mile truck, but couldn't find a good deal on a LWB truck that age, and this was a good deal for a VERY low miles truck in exactly the color and options I wanted.
This build thread will follow my modifications to the truck to make it into the ideal vehicle for me to explore the western US in all seasons. Every weekend is a 3 or 4 day weekend for me, and I like to do two 2 week road trips off the beaten path each year. So being able to just grab clothes and stop for food/fuel on the way out of town is the goal, everything else should be always ready to go. Hoping to get a pop up canopy style camper within the next year, ordering as soon as the Dodge sells, but long lead times leave it 4-12 months out. I'd love to be able to pull up to camp spots late and be in bed in a couple minutes, and head out in the morning in the same time frame. I'm not the hang around camp for two days in one place kind of person, always moving on each day.
As purchased:
As of 9/9/20:
As of 2/1/2021:
As of 5/5/2021:
Installed as of 7/24/20:
36" Toolbox
Fire Extinguisher in drivers door
4 Maxsa Escaper Buddies traction boards
Installed as of 8/2/20:
Weathertech front floorliners
Nite Ize Steelie Phone Holder
Sylvania ExtraVision 9007 Headlamp bulbs
Sylvania Zevo LED tail/brake lamp bulbs
Installed as of 8/6/20:
Front Neoprene Seat Covers
Dash Cover
New starting battery Odyssey 35-PC1400
Viofo A119 Dash Cam
Installed as of 8/22/20:
StartX remote start
Installed as of 9/9/20:
ARB Deluxe Winch Bumper
255/80R17 Toyo Open Country A/T III x5
KMC KM717 Black Satin wheels x5
Mevotech UCA (SPC without the branding)
All Dogs Offroad Complete Bilstein 5100 Kit with 100+lbs front lift springs and 400+lbs BrOverlander rear lift springs. Ubolt flip kit. About a 2in lift with winch/bumper and 400+ rear load. Probably 2.5-3in till I get the camper and winch bumper on.
17000lbs Sherpa Winch, overkill, but left over from my 3/4 ton Diesel, and should fit in the winch bumper, will definitely amp limit/alarm it to prevent damage.
Rough Country Speedometer Calibrator
Installed as of 9/15/20:
Custom Splice ARB offset hawse
Mile Marker winch shackle mount
Installed as of 9/25/20:
ADO Rear Axle Vent relocation to rear tail light
Midland X-Talker T71 2 way radios, moved to truck, but not "installed"
Sherpa 4x4 Big Air (10 CFM, nearly 75% more fill-up speed than a twin ARB, 90psi max pressure though, and double the weight/size), in truck, but not "installed"
Rokblokz mudflaps
Baja Designs Squadron-R Sport clear wide cornering lenses, swapping to Amber and wiring when the Motobilt panel comes in
Paranoid Fab ARB fog light brackets
Installed as of 9/28/20:
DIY 3/4" plywood 60% rear seat delete
Snomaster EX67D Fridge/Freezer
Used Valence U27-12XP LiFePO4 | 12V 138AH battery
Samlex 2000w PST2000-12 Pure Sinewave inverter left over from my Dodge for running a 120v chainsaw.
Renogy DCC50S 12V 50A DC-DC battery charger with MPPT Solar charging - BT2 bluetooth monitor/adapter(Vehicle charging only for now, no good place for a 200w solar install till I get a camper, this charger slows DC charging down to match panel output or 25A max, so a small panel makes for slower DC charging, I can get a full 50amp DC charge with no panel)
Installed as of 12/27/20:
Exhaust heat shield to protect my spare tire, only 1" clearance
Tow Mirrors - Found a set of heated Trail Ridge mirrors on craigslist NIB
Motobilt Switch Panel Housing - Top Surface Mounted (mounting in front of shifter), Wiring stills needs done
Installed as of 3/1/21:
Fumoto oil drain plug
Installed as of 4/19/21:
Diode Dynamics SS3 Pro SAE driving lights
Motobilt Switch panel installed
OTR Contura V switches for winch power lockout, winch in/out, fog lights, driving lights, rear lights, rear locker(sasquatch lights/heated mirrors till I get a locker), and air compressor
Installed as of 5/5/21:
OVRLND camper
Installed as of 6/9/21:
Brandmotion FVMR-1150 rearview camera and mirror/monitor
Floor insulation - 0.4" Minicell foam from DIYvan - Filled the .75in deep ribs in the floor nicely, then a sheet over the top
Covered floor insulation with 3/4" plywood.
1/0 awg wire from starter battery to front passenger side of truck bed
Installed as of 8/23/21:
Wiring/fuse panel to move electrical panel from back seat to the camper
10 Series 80/20 track and hardware for solar panel mounting from Tnutz.com
200w of solar, 4 x 50w SunPower flex panels
500A battery monitor (identical to Renogy)
Morimoto XB Hybrid LED headlights and Lasfit LED turn signals
Rugged Rocks battery terminals, super nice design for the Frontier and I assume other vehicles too, only Positive installed so far, need to order some right angle terminals and 2awg cable to make new negative cables
Probably install installed my Sherpa Big air for now, switch to a higher pressure system if I get an air locker
Installed as of 8/30/22:
1" Foam board insulation on walls/ceiling
Dual Viair 425c compressors, and 2 gallon tank, set for 120psi on / 150psi off
255/80R17 Falken Wildpeak AT3W x4
Rest of the 3/8" tubing and air fittings for my DIY UpDownAir
Propex HS2000 propane heater and install kit from gowesty.com
Expedition Essentials Propane mount and 10# propane bottle
Diode Dynamics SSC2 Sport White Flood Flush Mount Amber backlight - Backup/area lights and may use the backlighting as blinkers that will be high mounted on the camper - Currently not hooked up as I reroute some wires.
Diode Dynamics SS3 Pro Amber SAE Fogs - replaced the Baja Designs Squadron sports wide cornering lights that were too tall of beam for on road use. They may become ditch lights or get sold.
Koni Raid 90 Shocks with Heavy coils
80/20 build out of shelving, may build Built out in plywood to test it out for awhile
Android Auto head unit (also upgrade front speakers and delete rear speakers) also installed my 10" sub
Midland 75-822 CB and antenna on the bumper
Owned but not yet installed:
Led interior lights and USB ports
15 Series 80/20 track for the front and sides of the interior walls
Habitat Offroad recovery points Will require some modification to fit with the ARB bumper, and probably whatever skidplate I install too
Ordered:
Changes planned:
Insulation on sides of bed - Waiting on deciding my shelving final design
Changes I'm contemplating still:
Jerry cans and carrier
10-20 Gallon fresh water tank
Trans Temp gauge(Possibly add a full suite of gauges with a digital monitor, as the voltage, coolant temp, and oil pressure gauges are all dummy gauges that aren't super accurate)
Aluminum Skid plates
Area lights
ARB Air locker/s
180A or 270A alternator, stock should keep up fine, but if it goes out I'll upgrade
ARB or Coastal offroad rear bumper and rear hitch delete (May consider swing outs with tire/fuel if needed)
As purchased:
As of 9/9/20:
As of 2/1/2021:
As of 5/5/2021:
36" Toolbox
Dash Cover
Viofo A119 Dash Cam
StartX remote start
Rokblokz mudflaps
OVRLND camper
Ordered:
Changes planned:
Area lights
ARB Air locker/s
