Hey guys,
My old roommate (who has a 4WD Toyota Tacoma) reached out to me regarding buying a truck camper for his rig. Since I've seen a lot of FWCs on Tacos, I did a little bit of research and found that the Swift (935 lbs) and the Fleet (1,045 lbs) are specifically marketed towards the Toyota Tacoma. Just to be sure (I've had a few issues of coming close to GVWR) I asked my buddy to snap a pic of the payload sticker on his driver's side door and found that his Tacoma had a payload of 1,152 lbs (not including driver or passengers). Checking the forums, it seems that ~1,150 lbs payload is pretty typical for a 4WD Taco. Pairing a Tacoma with a Swift or a Fleet would come very close to exceeding the GVWR once you add the driver. Throw in a bunch of gear or an additional passenger and you’re over GVRW.
My question: Should FWCs market the Swift & Fleet towards the Tacoma, even though the buyer will be at max GVWR when the camper is on the truck?
Also: I completely understand this is not just an issue with FWC but other TC brands as well.
I would argue that the Swift & Fleet models should be marketed towards half ton trucks (Tundra/F150/1500). FWC should only market their Project M towards Tacomas to allow for adequate additional payload.
Thanks.
Thanks.
