Electrical schematic for 08 E350?
Abitibi
Hey crew
I need the schematic for my 2008 E350 to figure an electrical issue.
I know it's my own wrong doing but I think I broke or disconnected something in the engine bay that cause my ABS & Air Bag light to stay on. Can't clear the code either, no signal.
I also screwed the wire from the starter relay to the starter but for that one I just ran a new wire to fix it.
Anyone has or can point me to a schematic or proper manual?
Until I figure this out I can't insure my ambo so fir now she's just a cool land ornament...
Thanks
David
Sent from my SM-G973W using Tapatalk
willis102
No help with the schematics, but you might want to double check the pretensioner wiring harnesses to make sure they're properly connected and not damaged. Have you run OBD scan / do you get a code?
NomadQ
Not sure if it applies but, after installing swivel seats in my '02 E350, the ABS light came on for me because the pins in the connector under the seat weren't properly seated. Easy fix, and it cleared the light.
Bikersmurf
X2
I’d also check on the clock spring. If it’s disconnected the air bag and abs light will both be on.
My abs light came on when the connection under the drivers seat got bumped.
I’m not sure if it’ll trigger the ABS light but the sensor on the bottom of the master cylinder will mess up a bunch of things. Also the rear axle sensor... and wheel sensors.
My OBD II scanner won’t read any codes so I don’t know if there were any codes to read.
ilciclista
