Propane or DC air conditioner for hard shell rooftop tent?
billiebob
As we get closer to warmer months, concerned about heat while camping. Are there any good propane, DC or even AC (if can be run from inverter) air conditioner that can be mounted some how to hard shell tent?
A tent with AC sounds like overkill, but running propane to an RTT and living to tell the story seems like rocket science. Where as running electricity to an RTT AC unit should be Grade 8 technology with zero survival issues.
Definitely look at the electric choice.
In addition to the other constructive comments above, find a silver reflective fly for the tent.
ps..... if you run a genset to power that AC unit,,,, in the remote silent areas we all love..... expect someone to dump sugar into the gas.
PARK in the freaking shade.
Go for a swim.
Buy a spray bottle.
Evaporation is better than AC to cool down. AC in a lot of highrise office towers is injection of a water mist into the main plenum. Evaporation absorbs heat cooling the air......... ie
1950s Swamp Cooler
billiebob
Go for a swim is absolutely my favourite choice to cool down. I drove a semi with AC for years. After a day of sweltering heat, getting unloaded, reloaded and on the highway, I'd find a pull out near a lake or stream or....... change into shorts, grab a towel and bar of soap and go for a swim. 10 minutes in the water was better than a day in an AC cab.
A swim at 4pm should easily get you thru the night.
tacomabill
Someone over on Wanderthewest bought one and post a negative report:
SoCal Tom
1000btu/hour of cooling requires about 300watt/hours of power . A 100 amp hour battery has about 1250 watt hours. So if you completely drain the battery you get about 4 hours of cooling, but lead acid batteries shouldn’t be run below 50% power. So really you get 2 hours of run time for every 1000 btu. So 1 hour for the device above.
My teardrop trailer stays cool with 5k BTU cooling, which means I need a truckload of batteries to make it 8 hours, and a huge array of solar panels to recharge it. Or I spend 500$ on a 2 k generator.
joeyumbra
This report is about the 1st generation of the Zero Breeze, which had about half the cooling capacity of the current model.
emulous74
I have a Zero Breeze Mark II with two batteries and a 24v to 12v inverter to plug into a cigarette lighter or the ability to connect it directly to a 12v battery source. I live in Austin, TX and got this with the possibility to be able to camp in Texas during the summer, as temperatures are usually over a 100F. I've used it on my back porch, in my garage and in an alu-cab RTT and an iKamper X-cover. It makes the difference of sweating while you sleep or not sweating. It will only reduce the temperature by 25 degrees at most, the big difference is you can have the output pointed directly at you which will make you feel much cooler.
On the back porch when it's over 100 degrees I set it on a table next to my chair pointed directly at me, it makes it bearable to sit outside for extended time, like watching my puppy play in the kiddie pool.
In an unairconditioned garage, it will not cool down a small two car garage that is uninsulated, (I let it run overnight just to see) but it does help if you are working on a vehicle and it's pointed right at you. Much better than just having a fan pointed at you.
For the above two it's a luxury and I don't think it's worth the investment, a window a/c in the garage is much more effective and much cheaper.
In the Alu-Cab RTT with all the windows closed it will cool down the tent and keep it cool even during the day with sun bearing down on the tent, but remember, the Alu-Cab has closed cell spray foam in the top and bottom and very thick fabric walls. It doesn't just make it bearable, it makes it a great place to sleep and I don't wake up in a pile of sweat and have to air out my mattress and sheets.
In the IKamper X-Cover it is not powerful enough to cool down that much bigger tent with the sun bearing down on it, but the iKamper has much thinner fabric. At night what makes it better than just a fan with the windows down is it does an awesome job of dehumidifying the the tent, which makes higher temps manageable, again if you have it pointed directly at you, you will get cold. I recently bought iKamper's tent insulation, I will try the zero breeze out this summer with thee insulation layer installed and I have a feeling it will be working as well as it does in the Alu-Cab.
To me it's worth the high entry price, because I don't mind going on a short weekend trip in Texas during the summer, which before this, I always travelled out of state to go camping during the summer.
I realize it won't be worth it to everyone, but I'm also the guy that brings a Mr. Buddy heater along during the winter.
I say this sincerely, not being snarky.
I have camped in the Sahara at night in July without AC; just 2 way vent-fans, and open windows. Now I have more 2 way vent/fans and small low powered interior fans (plural) above beds.
AVOID nightmare places like specifically the American South in summer. Really sincerely.
It’s worse than the tropics. At least there you have the ICTZ to help you out.
Neither us nor our neighbors if any want to experience a generator all night.
Richardtij
Hello, this is an exciting question. Air conditioning is a perfect and incredible thing. You have a great idea, and it would be great to see how you implement it. The only problem is that finding a good, reliable air conditioner will be a problem because you need an unusual air conditioner. I, too, needed an unusual air conditioner for one of my ideas, and it took me a long time to find one. But one day, my one good friend recommended me a company that does any air conditioner ideas. They were accommodating and made me exactly the air conditioner I needed. They are also very good at repairing and maintaining air conditioners. They also fixed my air conditioner for me. So if you need help, contact them. I hope my information was helpful to you.
https://www.airconservicing.org/
Martinjmpr
Wiffleball Batter
The best way to keep your roof top tent cool during mid-Summer is to drive it to the Rocky Mountains and camp at 8000'+. ;)
Back in 2014 when we still had our little homebuilt wooden teardrop trailer we went to a teardrop gathering in SE Oklahoma. It was April so still pretty reasonable, weather-wise. Most of the other campers there had home-built trailers but we noticed every one of them had air conditioners running on 120vAC power (we were camped at a state park with electrical hookups.)
Most of them were from the Oklahoma City/Tulsa/DFW area and they said that in that part of the country you either had AC and camped at a park with electric power, or you stayed home, period.
RV owners have been wrestling with this issue for years. There's really no good solution other than having a 120v AC power source OR camping someplace where you don't need AC.
Here in Colorado we're fortunate. Because of our altitude and dry, arid climate, no matter how hot it gets during the day it always cools off at night. In fact, I bring a wool hat, gloves, and a winter jacket to all camping trips, no matter what time of the year. I don't always need it, but I always have it, just in case. It can get chilly at 9,000' altitude even in mid-August.
CharlieGreenT
