Short bolts definitely, or add crush tubes, You do not want the bolts to crush the tube, the bolts MUST have backing.is it fine to use longer bolts that go through the whole thing or should I cut access holes so that short bolts can connect the two faces that actually touch each other?
there is a youtube of just what you say behind an ancient Jeep Cherokeee off road, thru stream and his foam framed canvas wrapped tailer out performs his buddies traditional trailers. Using the xorrect springs is the secret.Anytime I towed a really light trailer, they bounce all over the place on bumps. The trailer tires would get airborne sometimes.
I don't know if you could dial that out of them with custom suspension. It would suck to build something awesome and have it get torn apart on the roads.
not sure about that, there are proven systems out there, if you must experiment have at 'er but....canvas will be soaked with likely a urethan-based truck liner which should adhere to the foam fine
yep. so much of design is just about function. you sit in a chair, it is 16" high..... why is that?Who in the world wrote that?
Tony
yeah i should get the book. it seems that everything still largely works if i jump down to 8" tires, but I have to be careful to make sure i get ones rated for 80mph as most of them aren't
lowered the roof while i was at it, but I still want the luggage area in the front for a few reasons.
canvas soaked in paint is popular on the Teardrops n Tiny Travel Trailers forum as Poor Man's Fibreglass, I read dsomewhere else someoen using truck liner but I didn't find that again. I'll likely use it on the outside anyways as extras protection against rock chips and the likenot sure about that, there are proven systems out there, if you must experiment have at 'er but....
80mph/130km/h is normal (unofficial) highways speeds here in the prairies so the tires should really be rated for them. Looking online as long as I'm fairly diligent about regreasing the bearings it should be fine.Are you planning to tow at 80 mph with a Fiesta? Is a Fiesta something different than the little Ford bubble I have in my head? Can they even go 80?
This is noted in some other threads here, but just because those little tires can hit, or are rated for, 80... doesn’t mean the wheel bearings behind them are. I’m guessing a super light trailer will get super squirrelly when a bearing seizes or a spindle breaks at speed!
Alternative thought, have you considered making a tent that pops up? Maybe just connect your wheels and frame to one half of a folded rooftop tent?
What are you towing with ?yeah i should get the book. it seems that everything still largely works if i jump down to 8" tires, but I have to be careful to make sure i get ones rated for 80mph as most of them aren't
... tracking down marine grade plywood, one of the downsides of living in a landlocked province. i might as well use normal plywood then seal it myself
I'm just a little bit wider then a 4x8 sheet of plywood, any narrower and a double bed won't fit.
.... waiting for my request to join the tiny trailers forum to be approved so i can get a final sanity check ...
