"Camper Crawler" Cummins swapped, do everything ,M1009 popup camper build
Yeah it looks great. Would you like to make my canvas top for the pop up I am building?
Sent from my Pixel 5 using Tapatalk
I could. Would just need dimensions.
Don't tease because I am serious. At this point I have zero interest in making it. I am almost done with my framing. After that is paint, skinning, and figuring out how I want to connect the vinyl and getting measurements.
What material did you use for your support hinges? I like that you welded it instead of bending it. Looks good like that. Also, can you provide a picture of the bump stops you made?
Yes I’ll get you some pics around 12pm central. The support hinges are made of 1inch emt. I preferred welding for this situation.
Maxx fan installed solar goes on tonight!
Are you planning to change colors any. I wonder how it would look if the aluminum angle matched the green on the truck.
Fj89
