We recently sold our 2020 sprinter 4x4 camper conversion and found an old DNR fire crew bus to build out. It's a 2006 F450 4x4 V-10 with manual 6spd trans and 4.88 gears. Rear axle is a Dana s110 with limited slip. Weight with seats removed 11,260lbs, rear axle 7,160lbs, front axle 4,100lbs. The box is just shy of 8 ft wide, 12 ft long and 6ft ceiling height. The box has a steel frame and skin (complete with tree branch pin striping. my favorite kind). This could be set up nicely for cold weather camping by applying some 3/4 - 1" closed cell foam like K-flex on the interior. Add batteries and a diesel heater and be good to go. The box is mounted to the frame with springs front and rear and feels really solid (no creaking or wobbling back and forth). My initial impression is that I will be comfortable driving longer distances on fire roads without worrying about it coming apart.
SIDE DOOR
BOX INSIDE
The rear storage locker is 30" deep.
Built in 2cycle fuel tank with external fill. It's currently designed as a gravity system for filling power equipment but it could also be used as a diesel fuel tank for a cabin heater.
SIDE DOOR
BOX INSIDE
