85_Ranger4x4
A quick update, using my oscillating cutter I cut along the top of the channel and removed the inside half of the ply wood above that.
Then I went back and made a few passes between the two sheets of plywood to get some wiggle roof for the bottom if the board stuck in the channel.
From there the channel worked off pretty easy.
I picked up a putty knife I can tap on to try to get the skin separated from the remaining board, just haven't gotten back to it.
I was planning on replacing all the boards just so it is done. What is making this hard is the boards basically have no rot, the bolts just pulled thru. I am going to re-evaluate the other three to see if they really need replaced.
