Rare Toy Hauler Adventure Rig (Build)
Arktisk
Quality work there. There is one of these "toy hauler" campers up the road from me and thought it was an interesting concept. I like what you have done with yours. Most hard sided campers are so dang heavy. I have an old Northland myself used primarily as a ski chalet.
Shapeshifter
Restless Adventurer
Thanks! Yeah when I saw the dry weight in the add I jumped on it.
jtcym1149
Sweet rig. Reminds me of the old school fleetwood outfitter. I like its ability to serve as both garage and cabin. Keeps those expensive toys away from prying eyes when traveling or staying in seedy areas.
Shapeshifter
Restless Adventurer
After using this rig a few times I decided it needed a porch.
There is only a small amount of tailgate that isn't big enough for a step and it makes crossing the door threshold from the folding stairs kind of precarious, especially in the dark.
This is how awkward the stairs and threshold were before:
As usual I wanted the porch to be as simple, lightweight, and as portable as possible. I decided to use a folding aluminum wheelchair ramp for the deck and a hitch mounted bed extender thing for support. I scoured the interwebs for ideas and never saw this solution so you're welcome for the idea ;)
The ramp/deck is rated for 1200 lbs but, being a ramp, it is designed to be supported at the ends. Since this the ramp is now a deck and is supported on the sides, not the ends, it wants to bow and buckle in the middle with a load on it. I made some simple aluminum blocks and mounted them at the "pinch point" between the hinge and these keep the ramp from buckling in the middle when a load is on the deck.
You can see that the stairs now mount to the hitch support thing. I also made some simple aluminum brackets that mate with the extension pieces on the support. When everything is pinned, it is quite stable.
Im super happy with how this turned out!
billiebob
Love this camper as a starting point. The problem with most campers today is they try to pack waayyy tooo much into too small a space.
This one with the open interior and cargo doors is perfect. Well done conversion too.
The receiver/deck extension is a best idea ever.
trackhead
Nice work. I have the same 12" stainless bowl cheapo sink that drains to the ground in my build, same Whynter fridge, and a very similar back cargo deck (ATV ramp). Simple wins (at least for some of us)
I used cables to support back deck, run them up to the jacks. Bomber. Avoids the long receiver hitch gizmo and allows for towing.
Shapeshifter
Restless Adventurer
Simple mod that gives me a rear view when the camper is on the truck. I mounted a cheap reverse camera below the camper porch light, then wired power to the camera from the porch light. I swapped the original porch light with one that has a switch on the housing so I can keep the camera power on but switch the light off while driving.
I wired a 1.3mHz video transmitter to the same porch light circuit and mounted it on the inside wall adjacent to the porch light and camera.
The 1.3mHz video receiver is mounted behind the dashboard and I use an adapter to get it to show on the factory display monitor. The adapter I use allows me to toggle between the factory apps and the video display on demand. It's a cool setup that I have used on a few different rigs. Since its wireless, I have a similar camera/transmitter on my pull-behind camper too. The dashboard video receiver picks up the signal from whichever camera is transmitting so regardless of whether I'm towing the trailer camper, or just the slide-in truck camper, I get a rear view. It works awesome for backing the trailer up.
ITTOG
That is awesome. Care to share details on the parts you purchased for the camera and how it is installed? I would love to do the same for my 2018 F150.
Shapeshifter
Restless Adventurer
The thing that makes it all work with Ford Sync is this - however there are several other brands that do similar things. I use a Navik like this one and I ordered it through their website where you can plug in your specific year/make/model to get the right one.
The video receiver is mounted in the upper glove cubby and gets power from the Navik adapter thing.
As far as reverse cameras, there are hundreds on Amazon or Ebay. I chose the one for this rig because of it's wide FOV. The video transmitter/recivers are very common too and you can find them made specifically for wireless reverse cameras (I use one of these to see behind the large spare tire on my Jeep https://www.ebay.com/itm/233967470762?hash=item36798c48aa:g:1xMAAOSwzk1gd7DP ). Most of those are 5.8Ghz frequency. The ones I'm using are 1.3 Mhz which tends to have a more stable signal and can penetrate steel and aluminum frames and obstacles better than 5.8. I saw your build! You will want 1.3 to transmit through that frame, even at 20 feet LOL!
Of course a more simple way would be to simply run a hardwire from the camera to the dash - still needing the Navik adapter though.
larsthor34
I love these, I remember seeing these before I picked up my Callen camper. I could never find one anywhere near me and it seemed like they were only building the smaller model "Cascade"? at the time. I like this better than my Callen because mine is a steel framed shell that sits on the rails with no floor. Still has a queen over the cab and I put a second queen like yours down below, in 8 ft bed. The plus side of mine gives full truck bed for storage and driving my quad up inside but it is a pain to take off...(i never have) without a floor. I have been looking for something in between this and a pop up for a long time. No one makes exactly what I am looking for yet but I do love these big open barn door style campers. Don't know why there aren't more options like this.
Jonny Adventures
