FS: AirDownGearUp platform/sleeper/drawers $700, NC
ncflyer
Got this when they started up and have since modified it to similar version of what they currently sell.
Platform, two lockable drawers, slide out platform on rt side (standing from the back) and section with support brace able to be added on left side for full platform covering rear with seats folded down. My plan was to have the rear seats out and in current state, the right side seat won't lock back due to rails extending further back than originally intended. Could be worked out with some careful grinding of center rear brace. I cut the drawers down to the current set up "low profile" version and left side is set a bit higher than left due to platform sliders on right supports but with easy clearance for the slide out tables that can be mounted on bottom of drawers. It's made of baltic burch and I had them coated with a water based clear stain. It has dividers in each drawer. The wings fold over to sit just above the wheel wells allowing access to side storage.
It secures with turnbuckes to the OEM tie downs or will throw in a base plate and shorter turnbuckles. They can be secured in line with the legs and
allow better access to side areas at front. Made for 5thGen so can't say how it may work in other versions.
$700.00 - No shipping - easy install and will work with standard rear area without deck. The platform was added to ensure a solid level surface but feet adjustable
ncflyer
additional pics. Fridge slide not included. Drilled for the Alucab tilting slide but flush using Tnuts so no problem with it removed. Front pieces removable. Just personal add on from spurs.
ncflyer
120 +/- rough guess. 150 with plate. Never did any specific checks. Will look back in info from ADGU for info.
Mitch Bears
