kevinclark
Asking 26k. Its ready to go! ONLY 2 YEARS OLD!
Thing looks new! Exterior, Interior and side walls perfect! Super clean!
Interior:
2 burner Propane stove with glass cover.
Sink with hot/cold water with 3.5 gal min pump.
Ducted heater with thermostat
Instant hot water heater. heats up in about 15sec. Has digital controller inside.
Has a Silverstone Corian countertop and backsplash that looks absolutely amazing!
18 + gal water storage. Comes with 18gal removable jug water storage system (3 jugs). This makes it easy to clean and fill. You could bring more water, there is plenty of room on the floor of the camper or under the folding sofa. This system uses a electric pump which easily connects to the water jugs. The connection is sealed and there is a stainless steel drip dray in case you have a spill. This also works great for wet items like boots, dogs or anything else that might need to dry inside. The system is very easy to winterize being so compact!
The outdoor shower also is connected to the hot/cold water system. It has a removable spray system that is stored inside.
There is a Overland solar system with mmpt charge control and a blue sea 12v accessory hookup. The system has 1 battery installed but a total of 3 batteries can be connected. I have 3 new amg solar batteries in the box I would sell for 1k.
There is a rollover couch with stock backrest. I has 2 additional custom memory foam cushions with soft microfiber removable covers made. The cushions fit the upper bed when extended to complete the bigger bed. They also fit the lower couch for sitting. They can be doubled up on the lower couch making it very comfortable when stealth camping. They can also add additional 3 in of bedding up top when sleeping. Lots of options and configurations!
There are 2 additional shelves that surround the window behind the folding couch making that area all usable storage.
I have extension brackets so it will fit bigger trucks. I have it on my Chevy Silverado but it will fit a 5 or 6 ft smaller truck as well.
Comes with bed mounts for a Tacoma.
FWC Fleet with Rollover Couch seating
Smooth white exterior package
4x camper jacks (manual)
mounting brackets
Forced air furnace w/ two 10lb propane tanks
Dual Fantastic fans
Batwing awning on passenger side.
Aluminum roof rack with cross bars
160w Overland Solar panel w/ MPPT controller
Exterior Options:
Exterior Siding-Smooth Aluminum Siding (White)
Awnings-Bat 270 Degree Wraparound Awning w/ Light $2,695.00
Camper Jacks-Mechanical Camper Jacks (4 corner) $950.00
Exterior Add-Ons Rear Wall Steps (better access to the roof) $350.00
Roof Racks-Yakima JetStream Roof Rack System (Complete) $1,450.00
Solar Options-Roof 160W Mounted Solar Panel w/ Charge Controller $1,425.00
Interior Options:
Cushion Fabric Colors-Deer Valley Canyon Fabric
Batteries:
2nd 12 Volt Deep Cycle Battery (dual batteries) $450.00
3.5 gal / min instant Hot Water Heater w/ Outside Shower Only — (no toilet, no inside shower) $1,225.00
Furnace-Forced Air Furnace w/ Thermostat $850.00
Interior Color Choices-Traditional Wood Grain Interior (Standard) $0.00
Sink & Stoves-Flush Mount Glass Top Sink & Stove Upgrade $675.00
Roll Over Couch Seating (Included w/ Base Model) $0.00
Subtotal $35,695.00
Weight On sticker! 850lbs
Total Price $35,695.00 (factory) Not including all the other upgrades!
Interior:
mounting brackets
Dual Fantastic fans
Exterior Options:
Interior Options:
Batteries:
Subtotal $35,695.00
