2021 Patriot Campers X3
PDXSting
Model: 2021 Patriot Campers X3
Color: Graphite (premium color option)
Mileage / Nights: Used ~4,000 miles / ~15 nights
PRICE: 51,000
Dimensions
: 13'l x 6'w x 6'h
Weight: 2,469 lbs dry weight (3,500 lbs GVWR) - 265lb Draw Bar
Title in hand, no lien
The first of its kind by Patriot Campers, the X3 is a live-in camper trailer that combines our famous outdoor living, 4WD track beating, tough as nails camper trailer with an easy to use, easy to set up, convenient indoor living area. Get the comfort of a live-in camper trailer paired with the unmatched offroad-ability and quality engineering that you receive only with Patriot Campers.
SLEEP COMFORTABLY
You’ll be resting easily on the oversized double 100mm thick, pocket sprung gel top mattress which comes standard on the X3. The sleeping area also comes equipped with a convenient zip-up cover allowing you to leave your bed completely made as you set-up and pack-down.
EASY ACCESS & SETUP
The X3 comes equipped with the CS3™ Integrated Tent, this tent can be accessed internally via the convenient fold-down stairs or externally with the adjustable lock-out ladder. The tent is not only easy to set-up and pack down, but it can be heated by the diesel hot water & tent heating system which comes standard. All entrances to the cabin are protected by high-quality fly screens that can be fully set up from the inside or outside, with the rear door up or down.
FEED THE MASSES
The X3’s L-shaped kitchen has all the functionality you know and love from the X1 with the added bonus of extra bench space, 2 external power outlets and enough space for the 75L fridge. All of the fold-down benches are scratch-resistant stainless steel, so you can prepare food right from the bench.
GET OFF ROAD
Independent Suspension keeps your camper trailer balanced and stable no matter how rough the terrain is. Best in class dual shock suspension prevents shock fade over long, rough trips and the unmatched handling of the X-Cruise independent suspension system keeps your trailer steady and balanced through any terrain.
Standard Equipment:
  • Laser Cut Decals
  • New Rugged Anderson Plug Connection
  • CS3 Integrated Tent With Hardtop Lid
  • Integrated PCOR Awning
  • X-Cruise 1.6-Ton Dual Shock Airbag Suspension
  • EXORACK Roof Mounting System
  • Redarc Redvision TVMS
  • Twin Water Tanks 34Gal (130L) Capacity
  • Diesel Hot Water and Tent Heating System with Utility Shelf
  • 1500 Watt Inverter
  • Lithium Battery Upgrade
  • Internal 120V Power Outlets
  • 16” Wheels – ET0 & 33” Mud Terrain Tires
  • Underbody Steel Spare Wheel and Tire
Optional Equipment and Upgrades:
  • Extended Drawbar - 200mm
  • Dometic 75L, CFX75DZ Fridge/Freezer with Anderson Plug
  • BBQ Swing Away
  • Weber Q1000 Propane Grill
  • Premium Color Change to Graphite
  • Lithium Battery Upgrade 100AH (Dual - QTY 2)
  • Additional Gas Bottle Holder - 10lb
  • Two (2) 10lb LP Tanks
  • X3 Windbreak Wall Kit (6 pcs) (never used)
  • X3 Drawbar Awning Sail Kit Inc. Poles & Ropes (never used)
  • Ark Trailer Jack XO750 Black Edition Extreme trailer tongue jack
  • Upgraded All Storage Liners/Carpet to Marine-Grade Carpet
  • Patriot Campers mesh ground mat (never used)
  • MaxTrax not included
    No known problems. In great shape. Will post more interior photos as soon as the sun shines here in Portland...
    Thanks for looking!
robtbritn
That's a nicely optioned X3, really nice! We have been enjoying our X1, tows like a dream behind our Land Cruiser. Good luck with your sell.
HaveeBear
Im unfortunately getting the same lack of interest on my x1H :/ hope yours sells soon
The Patriot trailers are premium products at $50k+. Market will be smaller - but there is a market - and it may take a while to sell - but will eventually sell...best of luck!
great7ven
No known problems. In great shape. Will post more pix as soon as the sun shines here in Portland...
Thanks for looking!
Hi is this one still available?
I had to sign up and wait for a period to be able to contact... Is this one with 240V as copied from patriot or US power with 120v? I do wonder if in the meanwhile the sun did better ;-)
JCCB1998
