where are the Porsche cayenne expo builds?
rader
958.2 CD build underway 😎
Scramblin_Jim
I've been slowly building up my 2015 CD for mild off road usage. I've added a Eurowise 2" lift, fitted 265/65R18 BFG KO2's on Alpha Grenad wheels, DirtCom swing out tire carrier, Eurowise winch plate w/o a winch as a recovery point, the complete underbody protection kit (skid plates and rock rails) from Eurowise, removed the rear seats and made my own sleeping platform. I've installed a 50qt ARB fridge/freezer on it slide, and made a cabinet to house a small microwave oven. I'm using a EcoFlow Delta 2 solar generator as my secondary power system. I've added a ham and GMRS radio, and iPad Mini to a Ram Mount system that got attached to the front center dash.
I picked up a Crux PCM interface module so I can run both a front and rear camera (currently my rear camera is blocked by the swing out tire carrier). I haven't figured out how to run the front video/power cable into the cab from the engine compartment. Does anyone have a solution?
I'm also wanting to add the Titan Fuel Tanks Trail Trekker II 12-gallon transfer tank the sits behind the spare tire. I haven't been able to get any sales person to get their heads around the 5x130 lug pattern verses the Jeep pattern used on the JK/JL Wranglers. Seems doable; looking for a dealer that has one in stock so I can do a quick fit check.
slomatt
A friend of a friend brought a 2016 Cayenne diesel on our trip to the White Rim Trail last Fall. We also took it on Fins N' Things and I was really impressed with how well it did, it definitely received a lot of double takes from people we ran into.
Smudge12
