2021 Titan XD Pro-4X
PirateMcGee
What is the number for towing?
Yes, for Supercab that payload is not too uncommon.
I might be wrong, but I can't name a crew cub with comparable payload
That's true. Mine is also a base base base model other than the rear locker ha. My Titan XD is much nicer quality, much better warranty, and better equipped and was cheaper than a base model f150 of the same year and miles ha.
PirateMcGee
Took another trip to the coast, lift is on, and now it's time for non snow tires and aftermarket wheels.
Leaning 17" bronze methods with 34x10.50r17 Toyo AT3s
Would post photos but I keep getting a parsing error...
PirateMcGee
Downloaded Tapatalk and it looks like photos upload easily!
Sent from my Pixel 7a using Tapatalk
PirateMcGee
Finally decided on a wheel and tire combo for my non winter set up. Ended up going with OEM 17" steelies that weigh 28lbs a piece which is pretty light. They also clear the calipers unlike the vast majority of aftermarket and are the correct offset to keep the wheel and tire tucked in the wheel well where they belong. I had them powder coated satin black and wrapped them in 255/85r17s (34.6" spec on diameter) Mickey Thompson Baja Boss tires including a matching spare for 5 tire rotation.
No rubbing at full lock with zero trimming and the spare fits just fine. Gained a little more clearance and side wall. Worked out perfectly!
plumber mike
After your reply on FB, I drove past a radar speed sign and my speedo runs 2-3 mph fast on the factory 265/60R20. You may actually be closer to accurate than I am now.
Where did you source the steelies?
PirateMcGee
Santa Ana Wheel. It reads a few mph low. I did a bit more rougher offroading and did experience some minor rubbing when hitting woops while turning. Will need to investigate it a bit more.
plumber mike
I’m not surprised. The factory setup has rubbed the mudflaps on mine since new. I did an oil change today and ditched the mudflaps. I noticed an incredible amount of corrosion on the battery terminals. Especially for a 2023 with only 13,000 miles. I’ve been reading about issues with the smart charging system and wonder if there is any correlation. Any issues on your last Titan?
PirateMcGee
No issues on either of mine with the OEM battery and charging cable intact. That said, my last one was topped up by my solar set up all the time. Going to ditch my OEM one on the XD since I am getting ready to install a winch.
NDC
