2017 F550 4x4 w/ Total Composites 2-bed + 1-bath camper @ 31k miles $300,000 - Reno, NV
unreng
We're selling our 2017 F550 4x4 with Total Composites 2-bed + 1-bath camper with 31k miles.
It's time to move on and let someone else enjoy the outdoors like we did last summer on our trip to Alaska - https://www.instagram.com/arcroamer?igsh=MW1obzhneGd3b2VpYQ==
This truck has a lot of room inside, quite a bit more than similar cab-over setups.
We purchased the truck from August Motors in Kelowna, BC in 2022 and took receipt of the truck in October 2022.
We spent the next 9 months learning the truck+camper and upgrading the systems for a trip to Alaska in summer 2023.
The instagram listed above & the list below detail these upgrades, as almost every system of the truck & camper was changed.
Items marked with an asterisk * were installed after we purchased the truck in fall 2022.
Dimensions are approximate.
2017 F550 XL with 6.7L diesel and 6-speed transmission
*DBL front axle Super60 / Dana 80 hybrid with 4.88 gears + *aluminum diff cover w/ Amsoil 75w140
Dana M300 rear axle with 4.88 gears + *aluminum diff cover (rare) w/ Amsoil 75w140
*20” single piece Nasa Wheels powdercoated black on Continental 335-80R20 MPT81’s
Kelderman air suspension - single front air bag + dual rear air bag with 4-link - https://kelderman.com/shop/2017-ford-f-450-550-c-c-4-link-rear-air-suspension
Hadley SAMS dual compressor + *new solenoid bundle + 4 ride height sensors + *upgraded Parker Hannifin air lines + *upgraded Anderson power quick connect + *75A Blue Sea MRCB
Upgraded to icon vehicle dynamics cdcv shocks front & rear Sept 2024)
*Titan 54-gallon midship fuel tank - https://titanfueltanks.com/products/cab-chassis/7020517
Ford 40-gallon after axle tank
Total Composites box + subframe + storage boxes + bumpers + fenders built by ArcLab in Winnipeg, MB
Front bumper + PIAA amber fog lights + Warn 16.5ti-s 16,500 pound winch + synthetic rope + Factor 55 thimble + *BlueSea 6006 on-off switch - https://www.warn.com/165tis-heavyweight-winch-97740
Rear bumper + Keeper 17,500 pound winch + synthetic rope + *Factor 55 Prolink XXL + *BlueSea 3000 on-off switch + *500A T fuse + *4/0 Ancor wire - (removed Aug 2025, will keep for the future owner)
Custom side steps upgraded to Amp Research power steps with Toyota switches at each door (Aug 2025)
*Upgraded Ford side mirrors for 96-inch panel bodies - 102" Extended Mirrors Available - Ford Truck Enthusiasts Forums (ford-trucks.com)
*Vinyl on hood to minimize sun reflection + *Lensun Solar 65W solar panel (MPPT controller included)
ARB 12v twin air compressor + *100A Blue Sea MRCB + *8ga Ancor wire - https://store.arbusa.com/twin-motor-onboard-air-compressor-ckmta12/
*Morimoto XB Gen 2 headlights + *LaminX film - https://www.morimotohid.com/Ford_Gen_2_Super_Duty_XB_LED_Headlights?quantity=1
*Putco Boss grill - https://www.putco.com/product/boss-grille/v/Ford/F350/2017/
*Rigid Adapt 30” light bar w/o GPS - https://www.rigidindustries.com/adapt-30-230413.html
*LUX lighting 8 piece RGB rock light kit + *bluetooth controller - https://luxlightingsystems.com/products/the-monster-led-rock-light?variant=43630713831587
Engine upgrades:
*Banks cold air intake - https://bankspower.com/products/col...f450-6-7l-power-stroke?variant=42326741221573
*Pusher intake - https://pusherintakes.com/pusher-powerflow-2015-2019
*No Limits intercooler – https://nolimitfabrication.com/i-30...6-7-air-to-water-performance-intercooler.html
*H&S hot & cold intercooler pipes - https://hs-motorsports.com/collecti...4-ford-6-7l-hot-side-intercooler-pipe-upgrade
https://hs-motorsports.com/collecti...cooler-pipe-upgrade-kit-black-oem-replacement
*SPE coolant reroute kit - https://www.spemotorsport.com/products/spe-motorsport-coolant-hose-reroute-kit
*BPD oil cooler - https://bulletproofdiesel.com/products/bulletproof-6-7l-ford-oil-cooler-90201157
*AFE oil pan - https://afepower.com/afe-power-46-70322-engine-oil-pan-black-with-machined-fins
*Banks iDash + *4 Datamonster gauges + *Pedalmonster - https://bankspower.com/products/data-logger-gauge-66760-all-2008-obdii-can-bus-vehicles
https://bankspower.com/products/ped...-booster-64310c-64313c?variant=40940401295557
*SPE internal catch can - https://www.spemotorsport.com/products/ccv-oil-air-separator-fits-2011-2020-6-7l-powerstroke
*Mishimoto CCV catch can + tubing from cylinder head to air intake...drain line to quarter turn valve under driver door
*Odyssey Group 65 PC1750T batteries (July 2025) - https://www.odysseybatteries.com/odyssey/pc1750.html
Espar D2 coolant heater + *EasyStart controller + *Remote+
* EZ Lynk tuner with lifetime dirtydiesel tubes- https://ezlynk.com/
4-inch stainless exhaust
*upgraded fuel tank filling & vent system w/ dual Atwood vents - removed deck fill fuel fillers from side wall & installed ford super duty fuel fillers front & rear, front & rear filler connect to both tanks with stainless wye’s. Fuel vents connect to both tanks & to both fillers & dual Atwood vents. (Aug 2025)
*diesel heaters & diesel stove connect to two Espar dual standpipes in the Titan fuel tank
Transmission upgrades:
*ATS Deep Trans Pan - https://www.lethalperformance.com/a...sion-pan-2011-2016-ford-6-7l-powerstroke.html
*MHX-520 oil cooler plumbed in series after the stock plate cooler - https://www.improvedracing.com/mhx-521-high-efficiency-oil-cooler.html – this helps keep the transmission much cooler than stock
*8AN Fragola HDPE hoses between transmission and stock plate cooler with MPP external cooler adapter - https://www.marylandperformanceproducts.com/products/mpd-11-19-6r140-trans-cooler-adapter
F550 Interior:
*Kingslim D6-4K dash cam hardwired - https://kingslim.net/products/kingslim-d6-4k-dual-dash-cam
Recaro Ergo MCii bucket seats front and rear – front has adjustable air suspension + *seat warmers -
*2020+ Platinum front & rear seats (front= heated-cooled-massaged capable, rear=heated capable) with center jump seat + *BigBlue harness https://www.bigbluecustomdesigns.com/store/p/fresh-pressed-juices-fppcj-ycysk-mgt94 (Aug 2025)
Kenwood DNX994S radio (Aug 2025) upgrading to *Alpine ILX-F511+ *front camera + *rear camera + amplifier beneath center console
Gamber Johnson center console + Icon IC-2300H + Cobra radio + *two locking bins - (Aug 2025)
Alpine TMX-R3300HDMI DVD player + remote + earphones for rear seats
*BGGD Raptor Steering Wheel + *optional heated steering wheel – https://www.boostedgreygoosedesigns...ifter-harness-2015-2020-f-150-wcolumn-shifter
*Dynamat Xtreme + *Dynaliner + *Havelock wool throughout the cab & doors to minimize sound transference - https://www.dynamat.com/products/dynamat-xtreme-2/
Outbound lockable 23” x 30” pass-thru from cab to camper
Total Composites Camper:
23.5-feet long
84-inch interior height (floor to ceiling)
92-inch interior width (wall-to-wall)
Outbound windows + hatches have sliding bug screens + blackout shades - https://www.outbound.eu/products/windows/
Hatch access to outdoor shower on driver wall (Aug 2025)
Collapsing aluminum entry stairs + mount on rear wall
Four subframe storage boxes - *Tecniq E32 light added to each box - https://tecniqinc.com/product/E32/
*Camper roof sealed with Korapop 225, then waterproof seam tape, them Liquid Rubber primer, then 8 coats of Liquid Rubber RV sealant
Stainless graywater tank – 60L with drain valve beneath truck + camlock connection with hose
Fiamma electronic awning with controls at door and electrical panel
*MORryde Safe-t-rail at entry door - https://www.morryde.com/products/safe-t-rail/
Cabover:
92” x 80”
6” king mattress (73” x 76”) atop Froli kit – 31.5” of headroom between mattress and ceiling (attention to anyone over 6’ tall [I’m 6’-4” and can sit upright without hitting the ceiling] - the headroom allows almost anyone to sit upright on the mattress, making the cabover part of the living area – no other manufacturer appears to offer this) - https://nickleatlantic.com/collections/star
8”D x 17”H x 54”L upper cabinets on passenger side
12.5”D x 13”H x 80”L lower cabinets on driver side
6”D x 6”H x 78”L cabinet along front
Front two Outbound windows are sealed shut from the outside (that’s how they were when we bought the truck)
*Outbound windows on drivers and passenger allow for supreme cross ventilation (added by Overland Adventure Truck Summer 2023)
Outbound hatch in ceiling allows for roof access
110V outlet + 12V outlet + red/white light for each side of the bed
*Dual 40”x50” curtains on sliding rail attached to the ceiling
Bath:
42” x 27”
MaxxAire Deluxe fan with remote + *Rolef fan cover with *Camco insulated insert - https://www.maxxair.com/products/fans/maxxfan-deluxe/
Thetford flushing cassette toilet with *extra cassette - https://www.thetford.com/products/toilets/cassette-toilets/
Faucet + stainless sink + shower + drain to gray tank
Motion-sensing red light eliminates the need to manually activate a light at night
*OrganizedObie storage bins + medicine cabinet - https://www.organizedobie.com/
Walnut slat floor mat
unreng
Kitchen:
22.5” x 51” stainless countertop
18.5”D drawers
Wallas 88DU diesel stove with *custom walnut cover + exhaust beneath truck - https://wallas.fi/product/88-du/
14” x 15” sink with walnut insert
*Hansgrohe 1.75gpm faucet (July 2025) with cold + hot water + *Seagull filter faucet (July 2025) + Ambassador Marine p-trap + Seagull IV X-1B water filter
Outbound entry door with window and sliding screen
Outbound window above kitchen counter
42” walkway between cabinet face and bath wall
12”D x 17”H x 96”L upper cabinets on passenger wall
Dometic stove fan
Wallas 86D diesel oven (currently removed July 2025) + exhaust vent on driver wall - https://wallas.ca/product/86d/
Vitrifrigo DP2600IXD4-F-2 NovaKool RFU9200 dual compressor fridge/freezer (July 2025) + *quad Cougar exhaust fans (July 2025) + *dual Noctua intake fans controlled by *adjustable temperature switch … custom hdpe intake and outlet grills
Vitrifrigo Icemaker - (currently removed July 2025)
Dometic Penguin 2 AC + *MicroAir easy start (July 2025) + *MicroAir thermostat (July 2025) - https://www.dometic.com/en-us/outdoor/rv-and-van/rv-air-conditioners/dometic-penguin-ii-13.5k-75419
Dinette:
60” x 92” (wall to cabinets x wall to wall)
34” x 44” custom walnut table with angle cutouts to allow entry-exit on rising/lowering base
Seating is 17.5” x 36” (x two) & 18.5” x 80”
Outbound windows in passenger wall & driver wall & *two Outbound windows in rear wall (added by Overland Adventure Truck in Summer 2023)
12”D x 17”H x 92”L upper cabinets on rear wall
180L stainless freshwater tank beneath passenger side dinette bench + locking water fill on passenger wall
Isotemp Spa water heater + FloJet 02840100 water pump with strainer & FloJet 02840100 bladder tank beneath passenger rear dinette bench - https://www.indelwebastomarine.com/us/products/product/show/water-heaters-spa/
Espar D4 + *Starlink + *solar + *CerboGX + *330AH lithium battery beneath driver rear dinette bench
Electronics + dual 300AH lithium batteries beneath driver side dinette bench – Outbound driver hatch provides external access
Rear dinette seat lids lock in open position
Side dinette seat lids utilize neodymium magnets to lock in open position
Both Espar heaters feature an *EasyStart controller + *Remote+
Electronics:
*rewired the entire camper for efficiency and access for repair – upsized wire as necessary to meet ABYC standards (safety duplex & <3% voltage loss)
4/0 Ancor wire from drivers alternator to a 600A Blue Sea bus bar in the electrical area
*330AH Victron battery added to existing dual 300AH Victron batteries - https://baymarinesupply.com/victron-smart-lithium-12-8v-330ah-battery.html
*Dual Mastervolt MacPlus 12-12/50amp DC-DC chargers + *80A Blue Sea MRCB for each to charge the house batteries while driving - https://www.mastervolt.com/products/mac-plus-serie/mac-plus-12-12-50/
*custom solar panel mount for the three solar panels – allows future expansion to larger panels.
*upgraded to Hyundai 410W Solar Panel 132 Half-Cell Bifacial HiS-S410YH(BK)] + *Aims Power disconnect switch + Victron 250/100 SmartSolar MPPT (w/ display) + *2ga Ancor wire + *100A Blue Sea MRCB
* Victron 100/30 SmartSolar Mppt + *Aims power disconnect switch + *450w ZOUPW folding solar with 50’ of 8ga Ancor safety duplex + *Anderson power disconnect. (Aug 2025)
*Victron Cerbo GX + 7” display - https://www.victronenergy.com/communication-centres/cerbo-gx
Victron Multiplus 3000VA + *4/0 Ancor wire + *Blue Sea 9003E on-off switch + *400A T fuse
*Victron Smart Battery Protect 220 + *Blue Sea 6006 on-off switch + *250A T fuse + *1/0 Ancor wire - https://www.victronenergy.com/upload/documents/Datasheet-Battery-Protect-65-A--100-A--220-A-EN-.pdf
Victron SmartBMV - https://www.victronenergy.com/display-and-panels/bmv-712-smart
*Starlink in-motion mounted to roof with router & power supply beneath driver rear dinette seat - https://www.starlink.com/roam
*Smartplug 30A connector + *30A breaker + grid connection to Victron Multiplus - https://smartplug.com/product/smartplug-inlet/
*Ruuvi Pro sensors connected to Victron system to detect temperature in the fridge + freezer + camper + cab + external storage + sleeper (these are mounted with velcro, so moving them is simplified) - https://ruuvi.com/ruuvitag-pro/
*SwitchPros 9100 8-switch added at camper door to control the interior & exterior lighting - https://store.switchpros.com/sp9100-switch-panel-power-system/
*Awning switch added at camper door
*Added KC chase lite as a secondary stop – turn – tail – reverse light above the spare tire - https://www.kchilites.com/28-multi-function-rear-facing-led-light-bar-9801.html
*Added aluminum strut channel to rear wall for attaching items.
Also included:
*2017 & *2020 Ford Service manuals on CD
*Two 8-ton US Jack D-56160 (for rotating the tires) - https://usjack-com.3dcartstores.com/8-Ton-Tall-Farm-Tractor-Hydraulic-Jack_p_46.html
*Checkers UC1600 safety chocks - https://checkers.justrite.com/wheel-chocks/urethane-general-purpose-wheel-chocks
*Smartplug 30A 50’ cord - https://smartplug.com/product/smartplug-cordset-with-push-type-park-power-connector/
*30A to 50A plug
Extraction equipment – shackles, tree saver, snatch block, GoTreads, etc.
Misc odd & ends originally included with the truck and many added along the way for future maintenance
*Spare Ford GL-8827 alternator
*Spare Ford SA-1142 starter
*Spare Ford FD-4625-AA fuel filters
*DBL headlight relocators
*Air lines to connect front tires to rear tires to transfer air – this saves time reinflating during a tire rotation
*Spare 3/8” and 1/4” Parker Hannifin air line
*RamMount GDS locking Dock and Intelliskin for Ipad Pro 12.9 - https://rammount.com/
We downloaded all of the build photos we could and uploaded them here -
unreng
more photo's here -
unreng
photos of the camper systems
unreng
exterior storage / hatch & chassis photos
unreng
spare items included with the truck.
unreng
how the the truck looked before upgrades
unreng
Photos of the equipment arrangement on the roof, the Alaska trip, and some recent winter shots.
The camper is well insulated, such that two adults and 1 toddler never had to turn the Espar on when the overnight temperature dropped below 0-Celcius.
We averaged ~13 mpg from Reno to Oympia, and ~11mpg on the 11,000 mile round trip to Alaska.
Dry weight with a full tank of gas (95-100 gallons) is ~18,000 pounds (weighed on CAT scale on 03-21-2024).
unreng
photos
unreng
photos
unreng
photos
TRAVR
Very nice rig, excellent presentation info, but couldn't find the length dimension of the overall rig. (Says camper measures 23.5, but overall?)
sunnyaz
