Circleback
Willing to sell truck as entire package or truck and camper separate.
Tacoma $10,000
ORU Bruin $8500
Bruin addons
- positive pressure vent to prevent dust intrusion
- molle panel driver side
All fluids changed on time
CLEAN TITLE IN HAND
PASSED CO. EMISSIONS
Pros and recently replaced:
Rear Diff locker
ball joints
Timing Belt
Water pump
radiator thermostat
fixed the clutch start switch
hood latch
cold air intake
alternator replaced
updated suspension - TOYTEC 2.0 aluma series boss 3" coil overs
HI clearance CV axle x2
OME DAKAR XL leaf springs
Rack and pinion and steering replaced
Drive shaft rebuilt
exhaust rebuilt
tie rods replaced inner and outer
power steering hose replaced
disc rotors up front replaced and brake pads
airflow sensors cleaned
BFG KO2 A/T tires 33 x 12.5 x5
Nomad wheels white x4 + spare
Swing out tire rack by RIGD
Camper is ORU designs hard shell BRUIN model w/ swing out doors
bike rack is KUAT fits x2 bikes
Lightbar up front
winch
Central unit replaced with ATOTO allowing BT connection
Truck spent most of its life in Arizona - no rust - slight surface rust today and Ive had past 3 years in dry heat of colorado
vehicle overall runs great
CONS
MAF sensor needs to be cleaned or replaced
A lot of paint chips on side and hood - to be expected
shes old!
Tacoma $10,000
ORU Bruin $8500
Bruin addons
CLEAN TITLE IN HAND
Rear Diff locker
ball joints
Timing Belt
Water pump
radiator thermostat
hood latch
cold air intake
alternator replaced
Drive shaft rebuilt
exhaust rebuilt
Lightbar up front
winch
CONS
shes old!
