re-charging a big power station while driving
DarrenPerina440
Hi all, looking for some help. I truck camp off the grid and I'm looking for a way (other than solar) to re-charge my Dakota Lithium power station while I'm driving.
My set up & needs -
2020Ford F250 (diesel)
Dakota Lithium PS2400 Power Station w/ DL 180W folding solar panel
I need to continually push an ARB Zero 47qt fridge, charge 2 E-bikes almost daily and charge small devices like phones and small LED lights.
My current set-up works for about 2 days, but I don't get enough out of the solar (nowhere near what DL advertised) to re-charge the power station but like I said, I can get by for a couple days. Once back on the road I can re-charge the power station from the cigarette lighter socket but it's not getting enough power to recharge enough (while still running the fridge).
The truck has a factory inverter but it's really weak(400w) and it won't push it.
I'm thinking a better inverter like the one in the link below but I'm just curious what other people are doing to re-charge these large portable power stations these days.....
Or would i be better off going DC to DC?
I apologize if this has been addressed here in the past.
Dave in AZ
Solar input 800W, 12-75v. I'm sure there is an associated amp limit they didnt put in specs.
1. Dc to dc, get a CONVERTER, run it off alternator, go to 70V, run 2x 8AWG wires back to the power station solar input. 11A about.Place converter near alternator to minimize large cables.
2. Or, inverter. Place inverter near alternator to minimize large cables. Run same 8awg wires for 120v 12.5A 1500W supply to power station. However... 12v at 1500W is 125A, your alternator can't do that without burning up.
You need to assess what your alternator can supply, the 400W existing inverter may be it.
Read my threads on this. Here is a summary one with vids
fratermus
FT boondocker
starter battery -> inverter -> wall adapter -> power station like you describe is a fairly common workaround for the issue.
As Dave points out having a 1500w wall charger does not guarantee your alternator will be happy to provide another 1500w (plus inverter losses).
180w of solar lying flat in the Brentwood area would average:
Solar wattage 180
Month Daily Wh Avg
Jan 340
Feb 540
Mar 741
Apr 942
May 1132
Jun 1294
Jul 1268
Aug 1135
Sep 923
Oct 681
Nov 427
Dec 317
Average 812
The above projection based on PVwatts
Buddha.
Finally in expo white.
Can you recommend any such converters that can live under the hood?
TwinStick
Personally, I would not put anything under the hood unless absolutely necessary. Heat is the #1 reason electrical things fail. Had a friend who went through a battery isolator every year.
Things I did in the past are not an option yet, that I know of. 2 trucks ago, I bought a 370 amp alternator, ran 2/0 1250 strand welding cable to aux battery and 2000/4000 watt modified sine wave inverter. I also had buss bars and fuses and a resetable circuit breaker. We ran an air compressor when needed and our 700w microwave. Never had any issues.
Now, we have a 23' Colorado ZR2. I haven't got into it yet. But we now have a 2000/4000 pure sine wave inverter and all the stuff from past trucks. Gotta come up with a game plan. I definitely want the inverter in bed but have to save up for a canopy camper first.
Now that I am 61, I gotta say that I noticed a big drop in my motivation-****.
Red Arc seems to be the ticket for electric systems in vehicles. Not cheap but neither is the vehicle. I have seen somebody's dream go up and burn to the ground. I made a mental note: not to be that guy, lol.
These new super high output batteries burn unbelievably hot. I'm sticking with what I have been using. But I have also given thought to Bluetti products. I could use inverter to charge it while driving down the road. Lots to ponder.
Good luck with your project.
Pacific Northwest yetti
Expedition Medic
In my truck camper, I have 300w solar, and the 4awg wire from the truck through an Anderson connector and a victron 12/12 30 DC/DC. It keeps my 200amp/hr lithium charged all the time. Its not even on the truck and my fridge has not been turned off since I installed it a few years ago.
Separate solar charger and DC/DC will both provide a charge at the same time. example, 30 amps from solar, and 30 from DC/DC when my truck is running.
I know my brother has installed and designed multiple systems for this for clients.
A system like the red arc, is maxed out at 30amps/ regardless of how much solar and dc power you have coming in. And if anything in it fails, the entire system is down.
TwinStick
I would look into the Bluetti. The reason I say that is I think I read that 1 model is capable of charging from 0 to 80% in 45 minutes and IIRC, is capable of 1200 watts solar and 120v simultaneously, which is why it can go from 0 to 80% so quickly.
That's the thing about power stations, they are constantly upgrading them every year and the older ones lose their value pretty quickly. I am leaning towards the Bluetti because you can add on batteries if you need more power or more reserve.
Personally, I like options, even if you initially think you wouldn't use it, you may change your mind down the road. I did like the 2 wireless phone chargers they used to have on the top of the 1 unit.
Dave in AZ
The OP stated he wanted to charge faster while driving. That means solar and dcdc, NOT 120v ac charging. Your Bluetti suggestion for him is bad guidance, that fast charging is for a guy sitting at home plugged into his living room...
I run a Victron Orion-Tr Smart 12/12-30A (360W) non-isolated DC-DC charger and high output alternator in my van to feed smart Li's while driving. I can run a Nomadic 12k BTU air conditioner off the Li's and keep them fully charged. The Victron lives inside the van.
taunger
