SOLD - 2013 Toyota Tacoma - Fully Built (Redding, CT) - Price Reduced
RunnerCT
RunnerCT
Bump in time for the weekend… and another item to mention on the truck is the lighting. The amber fog lights in front bumper (Rigid), new LED turn signals from ARB, new OEM headlamps, large round LED off-road lights on the front bumper, super bright. It has 8 rock lights (4 on each side), these are 3 LED cube lights. There are LED lights mounted inside the Alu-Cab. And the rear bumper has 3” cube lights (reverse) and the sequential turn signal lights which turn white when in reverse, these are mounted high on the Alu-Cab.
Military Sam
Hi. How does the superflow shower pump work and is it connected to a showerhead/release in the shower tent and/or kitchen prep area? How do you fill/empty the tank?
Thanks.
RunnerCT
Thanks.
Hello, I don’t have the pump hooked to the water tank, so it’s not currently working. It needs water line run from the tank to the pump. Previous owner never finished it and I didn’t either. I do have some of the connections that the previous owner gave me. Tank is 18 gallons, and has a small and larger opening for fill and drain. Thanks.
Military Sam
Got it. Ty
sunnyaz
