New member from abroad..
RoadRocket
The winch is a T-Max EWI 9500, the latest are also known as EWI-1000
Rated Line Pull: 10000 lbs. (4530kgs) Single-Line
Motor: 6.6HP Series-Wound
Control: Wireless Multicontrol
Gear Train: 3-Stage Planetary
Gear Ratio: 218:1
Clutch: Sliding Ring Gear
Brake: Automatic In-The-Drum
Drum Size: Diameter 2.52” (64mm) Length 8.82” (224mm)
Wire Rope: 100', 23/64” Diameter (30m, 9.2mm Diameter)
Fairlead: 4-Way Roller Fairlead
Remote Control: Included
the front-bumper is a standard series bumper, fitted with a (modified defender) winch-plate
sample:
