stevenmd
The 200tdi would be cool. But, $$$$
Grab a Rover v8 and build it a bit. Or, find you a Callaway.
I actually like the idea of keeping it all Rover but I also like the idea of decent mpg!:elkgrin:
Well, part of the reason the Rover gets such crappy mpg is because if its junk injection system. If you open the system up a little bit, and allow the motor to breath, the mpg's will improve.
With just an intake and carb alone, you'll see huge improvements in mpg. Mark at D&D claims that an intake and carb can bring 4mpg and almost 20hp to the Rover V8's. Of course, I have no way to confirm this.
But I can tell you that when the heads are re-worked, the power grain is awesome, and the mpg remains unchanged.
With a 4.0L Rover motor, some head work, hotter cam, and a nice intake and 4-bbl carb, you could be cranking 240hp with very little investment. Plus, all the parts to do this swap are off-the-shelf and State side.
It may not be the "coolest" combination, or even the most desired. But the guy has a wife and 5-kids; and we all know a wife cost a lot of money. The Rover V8 is the cheapest option to fill the "needs" of the OP's goal - more power, reliable, and drivable on the street.
A 200tdi could cost as much as $10,000 after engine, transmission, transfercase, and install. He might be able to find a deal and get the job done $6,500.
Who knows what a 4.3L would cost. You can get a wrecked Astro van for ~$1,000, but then you'd need some custom fab and a salad of parts to get it running. It would be like building a rat-rod. That's too "Kevin Willey" for me.
......although, I've seen a 500hp 4.3L before. That would bring a smile to anyone's face in a Series.
Rover V8... With carbs no less! Yee haw! All that work and then it drops a liner and you're back to square one. DON'T do this.
Worrying about gas mileage on an engine conversion project is utter nonsense. It would take me 12 years at 10k miles a year to recoup my diesel conversion costs. Engine conversions are not done for MPG.
Re-line it an pin it. Done. Several shops can provide this service, such as Robinson's and M&D to name but a few. Hell, the preferred Rover Specialist in Chicago has a very good machine shop that has done many without problem over the years.
Gas prices are only going to rise. Period.
I'd maximize MPG for any DD.
I take you have not done a repower project.
Kevin's right on here. Gaining fuel economy is the absolute last reason for doing an engine swap. It's a nice bonus but certainly not a reason to embark on a conversion.
At what cost? By the time you have sorted the many Rover V8 issues and have installed a non-junk ignition and fuel injection system, that 1000$ 60K mile take-out Vortec 5.3 and trans + 500$ aftermarket harness is looking really good, not to mention it gets better mileage and it will outlast the rover V8.
The only good justification for an engine swap is the one that works with your wife/SO/own conscience.
Wow, all excellent replies! More information than I expected. Also, more information to confuse me! Here is what I am after:
1 - Enough power to carry t
I have even more questions now:
1 - Is a diesel really that much louder than a Vortec V8?
2 - Will all the extra torque with a more powerful engine really tear up my remaining drivetrain? If so, should I upgrade the axles? But I already have the Sals rear end...
3 - Which would be better - the original TC or swapping in an LT230?
4 - What about the tranny? Mating up the auto that is in a rangie or disco or using a Chevy auto tranny mated to a rover TC? If a rangie or disco tranny is recommended, which one? Rangie or disco?
Thanks!
