Corey's 2007 FJ Cruiser built for expedtion/overland, & daily driver
Corey
OverCamping Specialist
Thanks, looking forward to getting a lot of use out of them.
Next item that will help with the fridge is one of those food sealing machines in another thread.
Gear
Explorer, Overland Certified OC0020
Great Thread. ((Do you have a link for the side lid mount hardware for the ARB Fridge.)Edit - I found the link on one of your other threads. Thanks) How are the hinges holding up. Any problems? I might try this on my Engle 35. Thanks
Corey
Justin, hinges are holding up great.
And it is nice not having to hold the lid open with one hand.
Corey
Phase One & Two HAM Radio Install 11-15-2008
This HAM radio setup will be taken in steps as it is very labor intensive, and I am taking my time on it also, as I am still working on my license.
I have all the gear on tap, and here is what I have.
Yaesu 857D HF/VHF/UHF mobile transceiver
YSK-857 Separation Kit to remote mount the faceplate of the radio
Diamond GLP58 mounting group to mount an antenna to the ARB front bumper
Diamond NR770HA 2 meter and 440 MHz (70 cm) mobile antenna (Will be getting an all band Yaesu ATAS-120a antenna in the future)
Valor VS4 Big Mouth mobile extension speaker (Got two, going to replace my present one for my CB radio)
Diamond MX62M duplexer (Allows two antennas or one ATAS-120a antenna to be used with the 857Ds two antenna connection on the radio)
And various small parts such as fuses and RG58U coax
I installed the antenna back on 10-29-2008, here are some pictures of the install.
This antenna is only for 2 meter and the 70 centimeter bands, hence why I will switch out later to the Yaesu ATAS-120a antenna.
I had to pick up some step drills from Harbor Freight to drill out the antenna hole on the ARB bumper, as the Diamond mounts stud is bigger than a CB antenna stud.
You pop out the plastic cap on the bumper by tapping it from below with a hammer.
Installed the Diamond mount and screwed the antenna to the base.
I still have to have the coax soldered at both ends for the antenna mount and the plug that goes to the back of the radio.
That will come another day.
The antenna is very stealth.
The Yaesu ATAS-120a antenna I will get later however is not so stealth.
Installed the remote faceplate of the radio today.
I used an existing mount in the rig which was for an iPod, cell phone, or GPS.
http://www.yotatech.com/50362018-post78.html
I took off the grip pod part of it, and much to my delight, the Yaesu faceplate kits holes line up perfectly with the holes in the Panavice mount.
I can even move it around for different configurations, and the holes still align up.
Picture one shows the Panavice mount only with the grip pod off of it.
Picture two shows the Yaesu remote faceplate mount bolted to the Panavice mount.
Picture three shows the Yaesu 857D faceplate mounted to the remote mount.
It is a perfect reach for me to reach out to adjust the radio.
The next phase will bet getting the the two external speakers mounted, and hopefully taking out the passenger seat to install the radio underneath of it and get the power hooked up to it, and the cables from the remote faceplate ran down to the radio.
Braz475
Very nice build man, top notch! I see you're in my neck of the woods...we should get together sometime for some wheeling/camping! I'm feelin' a NW expo get together, maybe some snow wheeling???
Corey
Thanks guy's.
Braz, I may be up for a spring run to Greenwater.
We usually plan a few easy runs up there each year.
Plus I will be camping more up there this year too since I got all equipped earlier this year with new gear.
Corey
BajaRack's FJ ladder installed 2-28-2009
Actually I installed it a few weeks back, but both brackets were not the correct ones, and new ones arrived to those of us who bought the first five ladders.
The new parts arrived 2-27-2009.
Saw the ladder mentioned over on FJ Cruiser forums website.
Very nice looking ladder, and this will allow me to undo the rear latch to my Autohome Maggiolina AirLand roof top tent much easier than jumping up on a rear tire.
Plus the ladder looks cool too :D
When the ladder was installed a few weeks prior to this buildup entry, the bottom clamp would not work, and they redesigned both the top and bottom clamps like the original one for their FJ Cruiser.
Installing it is pretty straight forward.
Below are some pictures of the install and finished product.
Tools needed:
13 mm Gear wrench and open end wrench on one end for the top bracket.
14 mm Gear wrench and open end wrench for the bottom bracket.
Assortment of Allen wrenches.
Pictures one through four show the ladder by itself, the new clamps, and the top and bottom clamps installed.
Pictures five through eight show the reason why my rig is filthy during the winter, two old growth fir trees I park under, ladder installed without spare tire, top of the ladder crooked after spare tire is on, and a shot with ladder and tire on.
Corey
Continued, ten picture limit per post, so I am breaking the post up.
Pictures nine through eleven show another ladder shot with the rear door closed, spare tire clearance, and a shot of the top bracket again.
If you have a bigger than stock size spare tire, you must pull the tire off the mount.
That top bracket is indeed on straight and flush with the door.
It appears the ladder became crooked though apparently after tightening up the spare tire.
I could hear the ladder creaking some as I tightened down the three lugnuts to the spare tire.
I can not figure out how it is crooked though, as the bolts are not bent, everything appears normal.
I am not going to fret over it though, the ladder is strong and secure.
I climbed up on it and even stood on the spare tire to examine the nice garden I have growing up on top of my tent.
I should have snagged a picture of that.
That will be cleaned off when warmer weather gets here and I break out my rigwashing supplies.
Links:
BajaRack
The FJ Cruiser ladder
Corey
Corey, overall how do you like your head unit? Especially it's nav abilities.
It seems I need a new ladder.
The top holes are not drilled correctly in the ladder as seen by another members installation.
The headunit I am very happy with it.
Like any GPS though, sometimes it is not perfect.
Coming up on a turn I am suppose to take, it may not speak to me until it is to late.
That has only happened a few times though.
Other than that, it is great sounding with the amp and new speakers I am running.
I only listen to Sirius Satellite radio in it, and sometimes the iPod which is interfaced with it.
WonaWarrior
