Cruise Moab 2009
Pskhaat
2005 Expedition Trophy Champion
Nope, we camped at "various" locations at slickrock due to some issues elsewhere...very long story. But yes there was an opening one night behind said showers after we requested to be moved from our earlier spot. The last night then moved into the "group" campground that was behind where Andre and Kurt were.
So that was you that we were behind on Poison Spider where I got bit by...a poison spider?
Moody
Needs to get out more
I was in the blue rainjacket:
Pskhaat
Right after you guys went up it started raining again. I'm not locked and I was in a 4 wheel slide down the fall line there a little further up, a little pucker, I had to bark the rear around and slam the rear back down in the sand there, but hekuva lot better than rolling...
cruiseroutfit
This years CM was a riot. I started out on Tuesday leading the overnighter in the Swell, we had a great turnout and Pablo arrange fro a special treat at the end of a long day on the trail.... the Lone Warrior Saloon. Cold beverages of all types on tap :cool:
Photos from the San Rafael Swell overnighter (courtesy of several different photographers)
Group lined up for Devils Racetrack and Eva Connover
The Lone Warrior Saloon
Paul running the bar
Setting up camp and our registration desk
Under the Interstate in Eagle Canyon
cruiseroutfit
That Paul May is The Guy to have around for a party... he's always at the bar.
There is a reason his nickname was "Gig" through college.
His construction was stellar. It all packed down into ~4' long, 6" wide and 12" tall, excluding the tap set. He has a method down to build them using scrap pallets, a true artisan. Local Cruiserhead Eric Cline supplied the homebrew. A very welcome treat to dusyt travelers after a long day on the trail (5 stiches, a bad fuel pump and serious moving with a large group)
