Blankets: 12 volt heated style
spressomon said:
My heated blanket (not the kind you typically see for $49...) goes just under the fitted sheet. I use a thick goose down comforter and stay toasty warm; so warm I only need to have the blanket on setting #1 (of 7 heat settings).
the type of comforter is probably the difference. I've tried using unzipped sleeping bags in combination with the heated mattress pad and it was nice, but down in the teens the sleeping bags have to be zipped to do any good.
And then the mattress warmer didn't make much difference.
Also, for extended use in subfreezing temps., keeping a battery charged enough to run do any good was more is more of a pain than just using an extra sleeping bag.
>But, of course, it adds little benefit to the frigid air temp when getting out of bed and getting dressed for the day.<
that was the other problem. Why bother getting up when you're so warm and cozy....?
spressomon said:
You'll love it...just make sure you have the battery amps to feed it ;-)
Right now my second battery is the auto store brand group 31 deep cycle marine, but i hope to get one of the Odysey/Sears Platinum ones soon.
I think mine on high draws 10-12 amps. So I just run it on med to high for about an hour before hopping in then drop the setting to #1/lowest which is fine for all but the coldest nights. I don't actually know what the draw is at this setting but assuming in the 3 amp range. I run this, along with lights, stereo, etc. off of twin Group 31 Lifelines that are mounted in my trailer. And, although I've only used it 2-nights in a row without running the alternator to charge back up, I've never had an issue.
Its so darn nice!
So, looking at this brand of 12v heated sleeping pad, I noticed that the 12v models are all only 60" (5') long. For anyone using these, how are you making up the difference. I'll need to make up 11.5", it seems like quite a hassel to work around. Expeicially for someone using a std twin size air mattress which measures 74" x 40".
Since the blanket is actually a mattress pad you lay on it does not account for the pillow area hence the shorter length.
bmonday said:
Here is one that is 80" long (and 40" wide), and only draws 3.7a:
http://www.exceldistributors.com/-strse-71/12V-Portable-Electric-Blanket/Detail.bok
I'm getting one.
BMonday
Ohhh, that's nice!! Plus it looks like it has the Off/Low/High switch that I'm also wanting. Great link!
I don't see why (with the adjustable temp units) you can't put this under you?? The avg temps range from 98.6* on the low setting to 120-126* on the high setting. So if you use the high setting just before bedtime, then set it to low for the night, you'd be good to go!
I sent an email to inquire about those (above) and the email did not go through??
I also noticed while searching around the web that a lot of the 12v blankets are constant draw, except those that have the auto off timer, but none seem to have a decent temp control. Except these: http://www.electrowarmth.com/fleet.php
So it looks like I'll be saving my pennies for one of the electro warmth units.
Well, after 'steaming' my wifes ankle with a heated stone a few months back, I dropped the $100+ for the 36"W Electro Warmth heated mattress pad.
With only a primary (Optima RedTop) battery, and no desire to drain the battery, I purchased an inexpensive 'portable power pack / battery jump starter' from wally world. At 300 amps, it's a little on the 'weak' side - but I'm hoping that it can at least get our bedding warm before crawling into bed at night...
It's first field test will be this coming weekend....
If this works, my wife will be a happy camper :wings:
Cold weather is one area where I knew rooftents would really excel. The idea is to extend the camping season and it is so nice to camp in places that are too busy in the summer and quiet and peaceful in the winter.
One goofy idea we had that works pretty well with the hard top tents is to get one of the cheap $30 12 volt lap blankets and put it in the tent and close it. Then you could run the cord down and plug it in when you are driving so when you stop for the night everything is warm and welcoming inside the tent.
The concept behind the Maggiolina is to keep the interior small so you body heat has a chance to warm it up like a mountaineering tent. Switzerland and Germany are the two largest markets for AutoHome. When you are on an extended trip, you need a larger tent so you lose some of the benefit of smaller size.
I had one client that did the GPS survey for New Mexico's emergency services. His job was to map ways to find people who didn't want to be found unless they had an emergency. He spec'ed a large Maggiolina because he was gone for days but was also up in high elevation in winter. I heard complaints about the tent being "cold". The only idea I had was what some of the guys use up in the Arctic, namely roll a big bolder into the fire, then roll it onto a plank and cover with foil and put it in the tent with you. He came up with the ElectroWarmth mattress pad, and really liked it. The drawback is that it uses a lot of energy at the same time your battery capacity drops because of the cold.
Before I left AutoHome in Mikes hands, we were playing with this concept. A heated mattress pad with a very low power consumption, less than 2 amps. You figure an 80 amp storage battery that has a couple years on it with 60 amps of real power at 10 degrees will only be able to put out 20 amps. Here is a link to the flyer.
http://www.autohome.it/images/accessories-news/sweet-pdf/Sweet-Dreams-GB.pdf
OK, it is expensive..... thoughts?
Dynamo TCX
