I believe the more direct the light, the better it will perform. That would be the same for any solar cell. Any light and it will deliver some power. This one does not require full sunlight to deliver enough to charge the battery at 14.4V , which is what my regulator delivers.... is your panel one that requires being directly in sunlight before it will operate at its peak potential?...
I'm not doing a lot of expedition style stuff YET - but, for an RV DIY conversion we're working on, I selected the PowerFilm 60W unit he did that post on. It's QUITE a unit!!
It already has grommets on the corners so you can hang it/attach it. They're smaller grommets. A Bungee cord, or, set of 'em would work find to anchor it just about anyway you want.
I'm looking at building up a foldable frame using Http://www.8020.net materials.
I'll probably have the second panel on its way some time this week. The tests with it have been MOST impressive - I've been seeing 17V+ in shady conditions with this panel.
I did order a MPPT charge controller to match with these panels. My basic understanding is that a MPPT controller is "set" so that when the panel is generating more voltage than the battery can handle, it "stores" that and sends it to the battery as it can, so, you get a more efficient panel.
On standard controllers, extra voltage just becomes heat - and, heat = wasted energy, that doesn't make it to the battery.
I'll post more as I know more!!
(From the looks of it, MPPT controllers are a reasonable amount more for the gains in charging efficiency from what I can see - again, will know a LOT more soon!!)
What I have so far isn't any more telling than what anyone else has posted so far, but, here goes..
the tester, reading 18.47V in the conditions you see - sun not even hitting it straight on anywhere. Rather shady conditions really..
the tester is hooked up with the panel laying exactly as you see it there, on a balcony, with no sun directly on it. I was pretty impressed by this!
I put some cup hangers on the ceiling so I could hang the panel during early morning straight sun - didn't take any pics of that, BUT, I did get 21V readings when the sun was directly to the panel, and, really, I probably would've gotten higher readings if it were earlier in the day. When I got the 21V readings, it was more mid-morning with sun almost coming straight down over the position of the panel vs. straight AT the panel, so, with sun straight on, I dunno what this would do!! Needless to say, I'm VERY impressed so far.
I did hook up some LEDs.
IN our RV, we have VERY basic electrical needs. LED lights, a MAXXAIR vent fan, and a 110V fridge running off an inverter.
Here's some more info on our conversion:
http://autolox.smugmug.com/Cars/Sprinter-Conversion/8765456_UWbXE#580180270_uP4Mm
We have all had to ask questions about solar energy so I am just trying to help with the learning curve. I never meant to appear critical of your attempts to learn more about solar. It is very good to get these things out and share them.
