Hello Everyone Newb starting out.
Flyn G
Just for reference, here was my LJ one 2 1/2" OME, TT, 1" Body lift & MM, and 33x10.50 BFG's...
Album Here:
http://s291.photobucket.com/albums/ll296/LumberjackJeep/2005%20Jeep%20Unlimited/
The tummy tuck did need to be dropped by 3/4" to eliminate vibes since no SLE but still gained at least 3" in the middle.
Dennis
Very Nice!
I think I'm on the same path that you took with OME 2.5 BFG and 33 x 10.5. I found a kit with and without the BL and MML. Did you run yours without the BL and MML prior? I'm reading conflicting reports about needing them with the 33s.
UCF has a nice looking transfer skid and has a version with and without the BL. You gain or lose and inch depending but for my use I don't think I'd miss the inch as long as the "shovel" is gone. I can't believe there hasn't been a class action suit just for being ugly on that thing.
Flyn G
JChatary
Outdoor Daydreamer
Welcome to ExPo Flyn G! Looking forward to seeing your progress on your rig!
Cheers! :beer:
bobDog
Newbie or not you do know this is going to eat up every bit of money you make in your life don't you? Of course you are going to have a great time and maybe a divorce or 2. But once you get a good dog everything will be fine! :sombrero::wings:
Lumberjack
Very Nice!
Flyn G
No, everything was put on at once, had an immediate vibe, bought some high density plastic to make the spacers for each side. Worked great and getting rid of the shovel is worth it, what Jeep had on their minds when they designed it is beyond me...
Dennis
Lumberjack
Yep, find a wife who like Jeeps as much as you do and you will never have a spare penny in your pocket again:elkgrin:
TJ Willy
There are some great suggestions here. I like Mexican Hippie's ideas. And he is right.
1" BL (my kit came with a radiator drop bracket so no motor mount lift was necessary) Back then, I lived in an apartment and put the lift on in the parking lot with a hi-lift jack and no help. Very manageable... With a budget boost you can get on 33's and it sounds like that will be all you need. There s a chance you will have to adjust your bump stops (especially if you disconnect the front. Another simple home remedy that I did was to use hockey pucks. I used wind shield installation glue to hold them in place on the bottom stop... never once lost one.
The later, when your stocker coils start to sag, you could spring (no pun intended) for a mild lift and pretty much leave your drive line alone. Most kits come with a t-case drop kit which sacrifices a little clearance but if you get into modifying that, you will need a SYE kit or much cheaper "hack and tap" solution. No opening of the transfer case. I went with a SYE and Woods shaft.
It never really ends with Jeeps. Just like other off-road/exploration rigs, mods become addictive. Jeeps are fun and simple to work on and I am sure you and your son would get some quality time busting knuckles together. The TJ is still wildly supported by aftermarket fabricators and parts are everywhere.
Unless you plan on some off-roading in the way of rocks or especially scenarios needing more than average articulation, you won't need disconnects up front. But they are inexpensive and nice to have. I made my own until I lifted high enough to need replacement links. Then I went with JKS. There are write-ups (mine is buried some where) on how to make your own 'quick disco's' which basically have you replacing hardware where they bolt on at the bottom.
I could go and on about the TJ. I miss mine sorely and very nearly went with an unlimited but decided the four doors were better for my little kids. (2 year old and six month old both in car seats)
The first thing I did was wire a kill switch to the ignition fuse under the hood. Hid the switch away under the dash and flipped it when leaving my topless/doorless Jeep in certain areas. Very simple.
One of my favorite mods was a Flowmaster 40 series with 2.5" pipe. Sounded great behind the 4.0. Check out Iggee seat covers on eBay. Nice protection from the elements. I feared no rain after lining my tub (Autozone - Herculiner - sprayed in) and installing those covers.
I had a blast at the ORV park in Hot Springs way before I lifted the Jeep to manage the 5's. You could go now since you are close, enjoy the trails, camp, and just be outdoors with your boy and the Jeep. Sounds good don't it? :) to
Attached was my TJ before I sold it money on our new house: @ Katemcy Rocks in Texas. Of course my JK build has an entirely different purpose. Though I did it, my heart never really was in the rock crawling... I am more suited for overland/endurance/exploration. It just took me a bit to realize it. :)
Enjoy your Jeep. Ownership gets you in the club.
By the way, I am from Arkansas and have family all over. My last house was in Benton. I miss the trees the most. Mesquite don't count!!!
:smiley_drive:
Flyn G
Money? Who has money? I just have (Expensive!!) hobbies. Mt. Biking, road biking, fishing, hunting, camping, raising 2 boys. The raising 2 boys edges more towards job than hobby though. I'm trying to build up a single speed mt bike for my wife right now too. It would sure be nice if Uncle Sam would hurry that refund check up!
Thanks for all the ideas and help guys.
Here is my short list as of right now. Purchase and install will no doubt depend on the mood of the financial director, current circumstances and little league baseball.
Phase 1:
33x10.5 BFG MT KM2
2.5 OME lift HD for LJ
LoD Rear Expedition Bumper w/out the tire carrier
LoD rock sliders and step (at the wife's request)
Phase 2:
LoD front bumper
UCF transfer skid
BL and MML if required (which will dictate which UCF I get but they are the same price either way)
Phase 3:Still reading on these topics...
Rack
Trailer
Tire carrier if necessary
Flyn G
Mexican_Hippie
Those are numbers I can sure live with.
Did the BB come with shocks or not?
I'm not into rock crawling or mudding so I think the less I do will probably be better for me in the end.
Flyn G
Yep, mine did. The BB's are basically 4 rubber spacers with shocks. You can usually get just the rubber spacers used on JeepForum or locally for $50, then add some shocks to it. Skyjacker Hydros are good and comfy, and you can get them very reasonably.
*every once in a while there are sales of Hydros, 4 for $100. They're #16016103 and #16016104, I think.
TJ Willy
Phase 1:
33x10.5 BFG MT KM2
Phase 2:
Flyn G
Again, MML not needed if your kit comes with Radiator drop... just in case you did not know.
Your gate will hold most 33's just fine.
Goldenbora
