Root Moose
How are you planning on rigging up the disconnects?
Brian, is the nut spinning in the socket or is the lug spinning with the nut or it just won't budge?
If the nut is spinning (stupid cosmetic OEM Jeep lugs - straight into the garbage with them) then go to Sears and get some of those craftsman nut/bolt extractor kits. Put the correct size over the lug, give it a couple of thoughtful smacks with a two pound maul, stick an L handle on it with the handle from your highlift slipped over and it'll come off no problem. (Bt/dt way too many times). Don't put the handle over a ratcheting wrench - it'll break.
Works great to remove locking lugs without a key too.
http://www.sears.com/shc/s/p_10153_12605_00952062000P?mv=rr
If it just won't budge do the highlift handle over an L-handle with the regular socket.
If it's spinning, can you get at the back side of the wheel at all? Use a dremel tool to cut the lug shoulders from the backside if you don't have access to OxyAce to cut it out.
Just stick a hi lift handle bar thing on the end of your breaker bar. I <3 leverage.
